04-18-2015, 05:05 PM | #1 |
Speed Freak
Drives: 2013 ZL1 Camaro, 2016 Camaro SS Join Date: Jun 2013
ERL block with pistons
ERL Superdeck block **Price Reduced**
-6 bolt head design -ARP 1/2 stud upgrade -Billet main caps -Bronze lifter bushings Approx 2000 miles on the block. Can handle 1200 hp no problem. Bore is 4.155, Includes Wisco pistons Approx 9.7 to 1 compression ratio Asking $3500. This includes block, pistons and shipping within lower 48 states.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date. Last edited by jessrayo; 04-29-2015 at 05:30 PM. |
04-19-2015, 12:18 AM | #2 |
Drives: Cts-v Join Date: Jun 2013
Why are you selling?
I'm assuming the pistons are for a 4" crank and 6.125 rods. |
04-19-2015, 09:03 AM | #3 |
AquaRob
Drives: ABM RS\SS; 69 427 Camaro; 1970 Z28 Join Date: Mar 2010
What ^ he said.
Centerline, Weld, Holley, Nick Williams, GMPP, Diamond, ARP, Callies, Nelson Racing, Pro Torque, Strange, J&S Polishing, RMCR, AAC, MBRP, Flowmaster, FAST, Comp Cams, RX Performance, Aeroquip, Spectrum Powder-Coating, Current Performance, RX,TDub Racing, DSS, Fore Innovations, Aeroquip, Earl's, BMR, Ximpac, MPD,Street Scene, Blood, Sweat and Tears
04-20-2015, 08:47 PM | #4 | |
Speed Freak
I elected to purchase an iron LSX 427 block. My crank, cam, heads will all fit and the O-ringing is much easier on a solid iron block I am told. I should have the block within a week and can start building it again. Once the engine is in we need to fine tune this compound boost project. Plan to go over 200 mph on compound boost in Oct. I considered keeping the ERL block for a spare but then I really need to purchase another set of heads and the matching set would still have to be O-ringed because I'm thinking I may be able to make as much as 2000 hp. I just decided that as much work as ERL has, maybe someone else is looking for 1200 whp or less and would be willing to buy the block at a discount. Yes the pistons are designed for a 4" stroke.
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date. |
04-29-2015, 05:31 PM | #5 |
Speed Freak
Anyone need an upgraded aluminum engine block?
04-29-2015, 10:01 PM | #6 |
Drives: 2011 Camaro 2SSRS YUDLOSE Join Date: Mar 2012
Got me saving pennies over here
^777RWHP/680TQ^ |
05-05-2015, 02:32 AM | #7 |
AquaRob
I assume pistons have valve reliefs to accomodate the 12 degree valve angle? Also, rings or no rings, and are the studs included or not?
thanks
05-05-2015, 09:27 AM | #8 |
Speed Freak
I don't know the exact design of the pistons, when everything comes out I'll post some pics. The rings will definitely be included. I was thinking I could re-use the studs in my next block.
05-05-2015, 11:39 AM | #9 |
AquaRob
Block, etc
You're running the TF 255 heads right? If so, then that's what I have as well.
05-10-2015, 04:31 PM | #10 |
Speed Freak
I'm pretty sure you are correct, Trick Flow 255 sounds right. I ordered them right out of the summit racing catalog if that helps....
05-17-2015, 04:54 PM | #11 |
Speed Freak
Bump, still have a good ERL block here.
05-28-2015, 11:10 PM | #12 |
Drives: 2009 CTS-V Join Date: Dec 2014
Pm sent
06-08-2015, 01:27 PM | #13 |
Drives: 2008 G8 GT Join Date: Jul 2014
Is this still available and if so, would you consider selling without the Pistons?
06-08-2015, 03:16 PM | #14 | |
Speed Freak
Sure, I will sell it without the pistons if this other party backs out. As soon as I know something I will post it here.
