02-01-2010, 02:19 PM | #1 |
Drives: 2010 Camaro SS/RS Join Date: Oct 2009
Long Tubes Needed with Supercharger?
I chatted with about 4 tuners this am and was looking at either the Maggie or the Procharger. Some say that the lt headers are needed and some say they are optional ....what are everyones opinions? Who did it and who didnt?
2010 IOM SS/RS LS3, Hennessey HPE550 Polished Magnuson TVS2300 Supercharger. 3.4 Pulley. Kooks long tube headers / high flow cats. GHL Full exhaust. ZL1 Fuel Pump/ADM FPCM. MSW Bap. JRE ZL1 Race cam with new springs/pushrods/Trunion Upgrade. FIC 850cc injectors. ZR1 Map sensor. CAI Induction. JRE Tune.
02-01-2010, 02:28 PM | #2 |
Drives: Speed Shop owner Join Date: Aug 2009
We have made in the 530-550RWHP range at 6-7 psi with the Harrop HTV1900 supercharger and no headers.
Full details can be seen here: http://www.lmspeed.com/harrophtv1900...hargerkit.aspx These superchargers are properly sized to be the most efficient on a stock LS3 engine. Thats not to say you're limited, as the HTV1900 is capable of 12-14PSI ! Please feel free to PM me if I can answer any questrions, Ed |
02-01-2010, 02:52 PM | #3 |
Drives: Vortech 'Charged 06 Mustang GT Join Date: May 2009
Totally optional, unless your goals exceed that of a normal bolt-on system. They aren't a bad idea, but with a supercharged application will always require a custom tune specific to the backpressure and airflow characteristics of the chosen headers. The last thing you want to do is run lean and hurt something...
02-01-2010, 02:59 PM | #4 |
Drives: Hoopty Winter Beater Join Date: Jul 2009
Here is our experience with a Procharger D1SC and 8psi.
http://www.camaro5.com/forums/showthread.php?t=58361 If you are not happy with 555RWHP, then you could always upgrade to LTs and a Cam to achieve 615RWHP. Here is the updated video. http://www.youtube.com/user/CincySpe.../0/G_XrLMU8sKw As Brian stated, make sure your tuner knows what he is doing. |
02-01-2010, 03:36 PM | #5 |
Drives: 2010 LSX Shootout World AM Finalist Join Date: Sep 2009
all of the cars we have installed maggies and pro chargers on we have put long tubes on them
02-01-2010, 05:56 PM | #6 |
Drives: 2010 LPE 650+ CTS-V Join Date: Oct 2008
Some tuners don't add them to their FI applications because it causes a loss of boost from lower back pressure in the system.
'10 CTS-V : LPE 650+ Package 587hp / 582tq
2.55 Upper / 8.6 Lower / ID850's / Kooks Longtubes / New Era CAI |
02-01-2010, 06:49 PM | #7 |
NOICE!!! ™
I went with kooks and couldn't be any happier
02-01-2010, 07:00 PM | #8 |
Drives: c6 corvette Join Date: Oct 2009
What does it matter if the car loses boost? Less boost will be safer on The motor and the headers will give it more HP.
02-01-2010, 07:31 PM | #9 |
Drives: everyone crazy... Join Date: May 2009
Here is the kicker; The F/I manufactures, vendors see headers as "options" and resellers and shops, see them as necessity. So you figure it out!
02-01-2010, 08:01 PM | #10 |
Drives: Maggie blown LS3 vette Join Date: Aug 2009
When you add boost to an otherwise stock motor, if tuned properly, it will make more power. If all you're after is a little more power and are on a tight budget, your motor will run fine with the stock exhaust.
HOWEVER, if you add long tubes and a free flowing exhaust, you'll make more power on less boost. Any time you can do this, it's a win/win. Less boost = less heat. Less is much better than more when you're trying to keep your engine healthy. High boost does not necessarily mean high power. Boost is simply a measure of restriction of the air going through the motor. The more you compress (boost) air, the more the air gets heated. As your intake air temp rises, your PCM will reduce timing advance. It protects your engine. If you can reduce intake air temps, you can run more timing and make more power. In short, there's no way I'd be without long tubes and a good flowing exhaust behind the LT's on a boosted motor. If the goal is more power, you really need them. |
02-01-2010, 08:03 PM | #11 |
Drives: 2SS/RS Join Date: May 2009
02-02-2010, 08:31 AM | #12 |
I just mentioned it because I was going to go with headers on my LPE package. They don't recommend headers on their FI installs. Maybe without them the engine will last longer - not sure. I just took their word for it, as I have no experience with tuning. Is there anything about headers that could add heat to the engine and be less safe?
02-02-2010, 10:05 AM | #13 | |
Boost is a Product of RESTRICTION. The Engine and the flow path of the gasses are the RESTRICTOR. If your HP Goal is 500 RWHP on PUMP GAS then you Don't Need Headers. If you want to get as much power as you can on as low a boost as you can then you Need Headers. Headers increase flow or reduce restriction of the flow path, which in turn lowers boost and makes more power. With a PD blower we typically see 1 psi boost loss and 10 RWHP Gain, this is good thing. With Centrifugals we will see a 1 psi boost loss and gain 20 RWHP gain, again this is a good thing. Another Myth busted, Headers Do NOT lean out the A/F ratios on these cars due to the MASS AIR METER measuring the additional Air Flow from Headers. Ted.
www.jannettyracing.com
02-02-2010, 10:07 AM | #14 |
Well said Ted
Similar Threads | ||||
Supercharger / Turbocharger Results (INFO) Thread | radz28 | Forced Induction - V8 | 273 | 08-15-2023 04:44 PM |
Long Tubes or Mid Length Headers? | TAG UR IT | Off-topic Discussions | 15 | 12-24-2010 07:43 PM |
Supercharging options available from BMC Performance! | Curt@BMCPerformance | Forced Induction | 17 | 02-18-2010 07:17 PM |
ProCharger Supercharger With Dynatech Long Tube Header Package | tbyrne | Forced Induction | 8 | 12-14-2009 10:59 AM |
