10-12-2016, 09:01 PM | #1 |
Drives: 2010 ss rs ls3 red-white rallys Join Date: Oct 2008
Dealer installed 3.91 gears price
What kind of price should I be expecting having a dealership install 3.91 gears with the speedometer update?
eps cam 226/234 lsa 113+2, bfe 1 7/8 headers, rotofab cai, katech oil pump, 444 rwhp, 411 rwtq, eps tune, Blanchard performance install
10-14-2016, 08:06 PM | #2 |
I'm thinking around $1600...
10-14-2016, 10:32 PM | #3 |
Drives: 11 2SS/RS M6 vert Join Date: Dec 2010
My install at my local garage was 300
LSA supercharger, Borla S-Type cat back, BMR/ Pedders Suspension, Kooks stepped LT's, GM 3.91, and RDP tune.
10-14-2016, 10:34 PM | #4 |
Drives: Camaro and Sierra Join Date: Jul 2012
I'm assuming he needs them to do all of the work. I paid $300 as well but took them the parts and the differential
10-15-2016, 07:24 AM | #5 |
I had an estimate last year and it was $1000.00 including parts to install 3.91 gear on the car.
10-15-2016, 07:33 AM | #6 |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
You can get an entire new 3rd member with 3.91and LSD for like $1800 or so? Speedo calibration is handle by your tuner(should do it for free IMHO)...
10-15-2016, 08:06 AM | #7 |
I don't think Chevy will do the speedo calibration if you have an after market tune.
10-15-2016, 10:49 AM | #8 |
Drives: '23 LT1 A10 Join Date: Oct 2015
Last year was quoted at 1600
24 LT1 M6 Sharkskin Metallic
10-15-2016, 01:18 PM | #9 |
Drives: 2010 2SS/RS Join Date: Dec 2009
Paid approx 800 but I supplied the gear set from Muareen also had them replace my stock axles with a set of 1LE's.
Orange Krush II
10-15-2016, 02:04 PM | #10 |
Drives: '14 1LE, Z28.R Join Date: Apr 2014
Why not just toss a 1LE rear diff in? They have the 3.91 gears and can be found used for $900-$1000
Far beyond stock....
10-15-2016, 03:38 PM | #11 |
USA-1
Where can you find one and then one at that price?
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete |
10-15-2016, 07:51 PM | #12 |
I bought my 3.91 diff from iamgmparts.com for $1353 + $100 in shipping. Cheapestgmparts.com also has them for a comparable all in price.
Part #22806794
Mods - GPI 416 w/Custom Grind Cam, Ported Heads & Tuned by Ben, Mag Heartbeat, ZL1 Fuel Pump & DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Circle D 3600 Triple Disc, RPM 5” CAI, Kooks Headers, Solo Cat Back, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Gulfcoast Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP |
10-15-2016, 08:43 PM | #13 |
I bought one with around 9k miles off the classified section here to have as a spare for track events. now that the season is over I was going to sell it but the person that said they wanted it disappeared.
10-16-2016, 04:40 PM | #14 |
Got an estimate of $1500 with the gm parts and tune and a 1 year warranty..
