11-21-2014, 09:39 AM | #1 |
Master Amateur Mechanic
Drives: Victory Red 2011 2SS/RS Join Date: Jan 2013
Real Top Speed of Camaro SS
I have done my research and as a 18 year old like to think I know almost all about our amazing machines. Limiter on the ss is 155. Once removed I remember reading a thread that said a stock ss could go 186 at top of 5th gear (assuming 6th gear was highway)
I just found an article stating a tuned zl1 hit 203 MPH. Does the zl1 have a different gearing ratio? Hypothetically, could a modified SS with stock 3.23 Gears hit 200 MPH (say 700 RWPH) What do you guys think!? Last edited by DaFisch; 11-26-2014 at 07:42 PM. Reason: mistype of gears |
11-21-2014, 09:50 AM | #2 |
Homeless Life Chose Me
Drives: LS3 (sold 4/21) Join Date: Nov 2014
Everybody knows 4th gear is fastest and 5th/6th are both overdrive.
11-21-2014, 09:55 AM | #3 |
Drives: 2013 1SS 1LE Black - Std Exhaust Join Date: Mar 2013
I do not know that this will be the case with the Camaro, but when we changed the engine in our 1986 SS Monte Carlo from the stock 305 (like 180 hp or so) to the ZZ3 crate engine (about 350 hp or so), and eliminated all the electronics that governed things like top speed, the care no longer was speed limited to 125 MPH. The interesting thing was that above that 125 mark, the nose of the car got very floaty and was not stable at all. I mention this because there are sometimes very good reasons to limit a vehicles top speed.
11-21-2014, 09:58 AM | #4 |
Drives: 2013 2SS/RS convertable Join Date: Aug 2014
Several have topped the 200 mph mark, some estimates believe with the power they could hit 240
http://www.camaro5.com/forums/showth...as+mile&page=5 http://www.camaro5.com/forums/showth...ght=texas+mile http://www.camaro5.com/forums/showth...ght=texas+mile http://www.camaro5.com/forums/showth...ght=texas+mile
2013 2SS/RS Vert
Mods list to long to fit in sig now lol Check build thread http://www.camaro5.com/forums/showthread.php?t=377507 |
11-21-2014, 10:06 AM | #5 | |
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint, Nitto Motivo Tires (6-8-18)
11-21-2014, 10:33 AM | #6 |
Chief Many Camaros
Drives: A paid off Camaro!!! Join Date: Mar 2009
Its all about power and the length of the road.
With our gearing, I think 240 is theoretically attainable engine RPM wise, but you have to have the power to push you there and a road long enough to let you get to that point. Realistically many modified SSs have exceeded 180 and a few have topped 200.
504hp/478tq Performance: Kooks LT, 3'' Exhaust, V-Max TB, Roto-Fab CAI, Custom Ported/Port Matched Heads and Intake Suspension: BMR Adjustable LCA's, BMR Trailing Arms, Poly Bushings, BMR Toe Rods Coming Soon (still in the box): Procharger F1R, G-Force Axles, 3:91 gears w/Eaton Truetrac |
11-21-2014, 11:10 AM | #7 |
Drives: 2012 LS3 SS 6M Join Date: Oct 2014
I read an article not to long ago that the LS3 is capable of producing speeds of 286MPH. Remember that's engine not car.
I forgot where I read it, I'll try and find It and post.
K&N Thyphoon CAI HURST Billet/Plus Short Throw |
11-21-2014, 11:18 AM | #8 |
Drives: 2012 Camaro 2SS/RS Victory Red Join Date: Jun 2014
I find that if I switch over to Metric (KPH) that my car is much quicker and faster. I think the PCM/ECM and even the BCM has a European tune built in for the better gas and higher barometric pressures over there. I've been drive in the Metric mode since I discovered this.
11-21-2014, 11:19 AM | #9 | |
Drives: 2010 CGM Camaro 2SS/LS3 Join Date: Oct 2013
The Camaro however does start getting a bit floaty over 130, it could use some aero to keep it planted, but aero will also hurt your top speed.
2010 2SS
BMR 1" Springs Koni Orange struts/shocks 1LE rear sway bar SRP Racing Pedals Hurst Billet short shifter Square tire/wheel setup Elite Engineering Catch Can Stainless Power longtubes/highflow cats K&N Typhoon CAI RPM Motorsports of Garner, NC dyno tune (421 RWHP) |
11-21-2014, 11:22 AM | #10 | |
11-21-2014, 11:59 AM | #11 |
11-21-2014, 12:15 PM | #12 |
Drives: 2010 SS L99 IOM Join Date: Aug 2012
A6 have stock 3.23 gears - and driving at those speeds on a highway is pretty scary @ times. Doing 155 twice on I-70 was enough for me and the car was still stable. So hopefully you won't do what I did but if you do be safe.
And to answer your question I think it will come down aero but with that much power it properly will but having a tough time pushing through. Just need a few miles(Texas Mile would be perfect)of straight -
369rwhp/392rwtq
"Spending money I don't have, to buy parts I don't need, to impress people I don't know!" -Jenkins Last edited by i2disturbedSS; 11-22-2014 at 01:35 AM. |
11-21-2014, 12:19 PM | #13 |
Drives: 2010 Camaro SS, 2018 Colorado Join Date: Nov 2009
11-21-2014, 12:49 PM | #14 |
You just need a HDMI cable
369rwhp/392rwtq
"Spending money I don't have, to buy parts I don't need, to impress people I don't know!" -Jenkins |
