Old 12-16-2017, 09:03 PM   #1
2010_camaro
2010_camaro's Avatar
Drives: 2014 Camaro SS
Question What's the better intake for boosties
So I was looking at the Holley or edlebrock single plane or the new trending sheet metal mid ram intake.
Pros and cons on both would be great.
MODS 6.0 forged iron block, TH400, B&M shifter, DSS axles & driveshaft, Viking / BMR suspension, Full custom fuel system with cell, Twin 76mm teriyaki tornados on 24lbs.
https://www.instagram.com/whoopa_ss/
2010_camaro is offline   Reply With Quote
Old 12-16-2017, 09:40 PM   #2
Clarkstar
Clarkstar's Avatar
Drives: 2013 1SS 1LE
Check out lod speedworks...
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq.
Clarkstar is offline   Reply With Quote
Old 12-16-2017, 09:41 PM   #3
Clarkstar
Clarkstar's Avatar
I've read many threads that the elbow on the single plane is too restrictive....
Old 12-16-2017, 09:49 PM   #4
2010_camaro
LOD intake is over $1000 more. Lol not looking to spend that much.
Old 12-17-2017, 05:07 AM   #5
racesloth
Dan
Drives: 2010 Camaro 2SS IOM
The stock intake is good for 1K horsepower. proven time and again...
Save on the intake and spend in other areas...
Dan
2010 IOM SS
YSI-B, Pat G Cam, Ported CTS-V Heads, ARH LTs MBRP 3" exhaust
http://www.camaro5.com/forums/showth...&highlight=ysi
racesloth is offline   Reply With Quote
Old 12-17-2017, 08:53 AM   #6
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
I'm using the holley high ram. You'll need an aftermarket hood though.
the single plane intakes are good if you have a pcm that can add fuel to the back 2 cylinders. they don't do very well at distributing airflow
ttshovel is offline   Reply With Quote
Old 12-17-2017, 08:58 AM   #7
blake-b
blake-b's Avatar
Drives: 2009 ZR1
And cut your cowl
Old 12-17-2017, 06:27 PM   #8
2010_camaro
It's time for a intake now lol
Old 12-17-2017, 06:32 PM   #9
Clarkstar
Clarkstar's Avatar
I hear ya... the main problem with the stock one is its not attractive... I'm in the market for a new one too!
Old 12-18-2017, 07:36 PM   #10
stevieturbo
Drives: it changes
For all round performance in the rpm range most users actually need....stock types are bloody hard to beat.
If it's for visuals then yes some of the Holley etc offerings do fit the bill, but expect a loss in performance over most of the rpm range ( unless you use 6500+ often ) and they do represent good value as long as the quality is half decent.
The LOD Speedworks one....they popped up advertising a while back, but then seemed to disappear, so no idea if they ever made it into production ?
Another who has popped up on some forums advertising was G1Pro, and although they could supply no evidence of testing to support their claims, the fabrication work is excellent, and range of options also pretty much unmatched. They'll pretty much build whatever height and runner length you want, within what will fit etc.
But you're back into bigger money again.
http://goertz1.pro/product/lsx-terminator-hi-ram/
Or if you dont quite have the room for a full HiRam, Shearer is offering this setup which is pretty cool. Would be nice as a fully fabricated piece, but using the Holley base would keep costs down I'm sure
http://shearerfabrications.com/sf06-05001.html
stevieturbo is offline   Reply With Quote
