04-14-2020, 11:01 AM | #1 |
Drives: Chevy Camaro, Chevy Traverse Join Date: Apr 2020
14ss Whipple Install
I have a 14ss convert. Im gonna put a Whipple S.C. on it.The instructions say the tune they send needs to use the orig.
aircleaner box with the bottom cut out, I already have a cold air intake.I have a Diablo I2 tuner,is there anybody out there that can make a custom tune to start the vehicle . Im gonna get it dynoed in the end, Any help would be appreciated. |
04-14-2020, 11:47 AM | #2 | |
Drives: 2015 Camaro SS/1LE Join Date: May 2015
https://www.camaro5.com/forums/forumdisplay.php?f=74
2015 2SS/1LE/RECARO/NPP/RS/NAV
04-30-2020, 08:37 PM | #3 |
Drives: 2014 1SS/1LE Join Date: Nov 2015
The difference between the Whipple air box mod and a CAI is not that big if you just need it to run well enough to get to the dyno. I was able to drive 45 miles on a base tune, just stay out of the boost.
Sent from my Pixel XL using Tapatalk
