07-21-2011, 06:30 AM | #1 |
HELP - Speedometer quit working @ 64,000 miles
I just turned over 64,000 miles the other day. I have had the problem about 3 times in the last month. After sitting in the parking lot while I am at work on sunny days, my analog speedometer does not work. It will normally work the next morning or later that evening once I have let the car cool off and restart it. However, it did not work yesterday after work and it still was not working this morning.
I have no warrenty, but wonder if this would be covered under defect? I am also a little upset becasue I had some paint just peel right off the front bumper the other day while washing it and have had paint peel off twice around the back of my spoiler.
2010 Camaro 2LT / RS - Black w/IO interior & M6
Sporting MRT V1, Hurst short throw, and Injen long tube and loving it!!! Also, over 125,000 miles and going. |
07-21-2011, 07:03 AM | #2 |
Slow Turtle
Probably a gearbox issue. There is a tiny screw/round gearbox assembly on the backside of the needle, on the actual circuit board in the cluster. The earlier cars had issues with them. If you're inclined, you could disassemble your cluster and attempt to repair it. Often, the screw just comes out of its track, since it's just press fit by the actual gearbox cover (shitty design). Otherwise, a replacement cluster is relatively inexpensive. They're around $200, but you will have to pay to have it done at your dealer because the cluster is a controlled inventory item, they have to return your old cluster.
Good luck |
07-21-2011, 07:08 AM | #3 |
Drives: 89 IROC 350 Join Date: Mar 2009
I've heard of this before. Try the dealer first.
07-21-2011, 07:11 AM | #4 |
Drives: Love the one you're with Join Date: Sep 2009
Some of the earlier 2010's had a problem like this. Check with your dealer. There might be TSB on it.
07-21-2011, 07:14 AM | #5 |
n116
Drives: 2010 2SS YELLOW TRANSFORMER AUTO Join Date: Mar 2010
My wife's cluster went out on her avalanche after no warranty and the dealership just charged me labor for install, no charge for new cluster. I felt good about the price.
07-21-2011, 07:17 AM | #6 |
Thanks to everyone for the help.
07-21-2011, 07:23 AM | #7 |
min still doesnt work... well.. only when it wants to... then it dies all over again...
good thing we have a digital speedo
SHOCKWAVE - 2SS/RS/M6 - Blk/Blk
JRE Tuned - ARH LT 1-7/8 w/Cats - JRE Rear 4.11 - Borla "S" Cat-Back - CAI by CAI - H&R drop - HURST Shifter - BMR Tunnel Brace; 4 Point Brace; Adjustable Toe Rod; Rear Trailing Arms - Sphon Control Arms - MTI Racing w/Fire Sleeves - Stealth Ambers - GTS Tails - Phantom Grille - Concept LED Sidemarkers - Blacked out logos - Hotchkis Bars & End links - BMR Front Driveshaft Loop (install soon) - BMR Subframe connectors (install soon) http://www.cardomain.com/ride/3813191# |
07-21-2011, 08:01 AM | #8 |
I agree with that, HzMajesty.
I find it odd though, that everything else is just fine.
07-22-2011, 03:47 PM | #9 |
Drives: GM Vehicles Join Date: Jun 2010
Rocks RS, have you ever spoken with our Customer Assistance to see if there would be anything we could do for you? Thank you for your time.
Jeff Morris, Chevrolet Customer Service |
Thread Tools | |
Similar Threads | ||||
Dash gauges not working and clicking noise | Tigerrag24 | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 26 | 02-26-2013 02:16 PM |
Have you had as many problems with your 2010 Camaro as I have? | KeepItGreasey | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 121 | 05-06-2011 10:53 PM |
Analog Speedometer Not Working | fieldgoal00 | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 26 | 08-22-2010 11:31 AM |
Gauges quit working | rlhjr34 | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 4 | 06-16-2010 03:10 PM |
almost as 10k miles (9800)... my thoughts | bob2the2nd | 5th Gen Camaro SS LS LT General Discussions | 5 | 11-13-2009 01:30 PM |
