06-12-2012, 11:09 PM | #1 |
The Man in Black
Drives: 1969 Camaro 2010 Camaro 1SS Join Date: Apr 2009
HELP tire issues
Got my forgestars on the car 9 inch fronts 11 in the rear
I'm running p zeros 275s on the front that I bought with 2000 miles on them and nto5s on the rear The front end has a shimmy , and it pulls to the left Just had stock rims on it was fine no pull no shake Had another after market set with new tires invos before had other issues but also a shake they were 9 fronts 11 rears this pair came mounted and I had them rebalanced still had a shimmy they were returned Im lost help ! Any ideas greatly appreciated .... Going to have them rebalanced again And make sure they used the centering rings |
06-12-2012, 11:30 PM | #2 |
"Camaro Joe"
watch out for a broken tread this could cause that issue too
06-12-2012, 11:43 PM | #3 |
Swap your front wheels from side to side and see if the pull changes direction. Sounds like you might have a bad tire.
ProCharger P1X, Vengeance Racing Kaotic Cam, ARH Headers and Exhaust with Borla ATAK mufflers, MGW Shifter, MTI Drop Springs, Forgeline RB3C Wheels, 3.91 gears, Night Owl LED Control System
06-12-2012, 11:50 PM | #4 |
The Man in Black
Yeah I just need time to trouble shoot
Tires are pretty much new but I guess anything can happen I'm thinking maybe the centering rings weren't put on |
06-12-2012, 11:54 PM | #5 |
The Man in Black
Would a bad tire be visible during the balancing process ?
06-13-2012, 07:09 AM | #6 |
Drives: 2010 CAMARO 850 RWHP/733 RWTQ Join Date: Sep 2010
Sometimes it may show up during balancing,depends on how bad the tire is.. slight belt slippage or out of roundness may not show up during balance. But if it has a decent shimmy and pull i would think you would see it during balancing..
*Night Fury
*Vortec YSI *Alky Meth *RPM TH400 with Brake *Precision 3600 Converter *850 RWHP/733 RWTQ |
06-13-2012, 07:14 AM | #7 |
The Man in Black
That's what I was thinking
I'm really hoping the hub centric rings weren't installed and it's an easy fix Buying new tires right now don't fit in the budget |
06-13-2012, 07:18 AM | #8 |
"Camaro Joe"
a roadforce balancing will show any defect in the tires
06-13-2012, 09:01 AM | #9 |
The Man in Black
Ok the balance was off so far no shake no pulls although 500 plus to the wheels in the rain with nto5s I can't really get a good feel for anything but it's def better than it was
The shop said that sometimes with used tires the car has to be driven and rebalanced Indint believe them but there's def a difference more info once I get a dry road |
