Old 09-07-2014, 03:03 PM   #1
Camaro_Mike
Drives: 2011 CGM SS LS3
BROKEN AXLE/DRIVSHAFT
hi guys, i recently just brought a 2011 2ss ls3 camaro. i know about the issues with the irs. what causes the axles/driveshaft to break and what can i do to prevent my axles/drive shaft from breaking?
PS i plan on lowering the car about 1.25-1.4 inches in the future with coilovers
Camaro_Mike is offline   Reply With Quote
Old 09-07-2014, 03:07 PM   #2
Merc
In The Circle
Merc's Avatar
DSS axels and driveshaft. Diveshaft is the weakest link.
Old 09-07-2014, 03:53 PM   #3
Synner
Drives: cars
Wheel hop and horsepower
trailing arms, cradle bushes, alignment
Old 09-08-2014, 09:58 AM   #4
Camaro_Mike
You know of any other mods to help keep the axles/driveshaft from breaking?
Old 09-08-2014, 10:04 AM   #5
Synner
Drives: cars
Try reading my post...
Old 09-08-2014, 10:12 AM   #6
BMR Sales
BMR Sales's Avatar
Drives: Race Car
As Synner mentioned, wheel hop is the biggest enemy of the factory axles. Combine wheel hop with high torque and your axles are sure to have a short lifespan. Upgrading the axles is a great upgrade and obviously gives you a stronger axle, but doesn't resolve the cause of the problem. Here are the common replacement parts to reduce wheel hop:
1.) Trailing Arms and outer trailing arm bushings.
2.) Cradle Bushings (I recommend the full bushing replacement, not "inserts").
3.) Toe Rods (preferably adjustable).
4.) Rear Upper Control Arm Bushings (BK039 are the best).
These don't have to be done all at once, but the quicker you address these weak points, the better off your axles will be.
Old 09-08-2014, 11:25 AM   #7
Merc
In The Circle
Merc's Avatar
No if you have manual they are brutally hard on parts if your drag racing at the track. I have all the BMR stuff for my M6. I killed the stock diff and a Jannetty modified 391 diff. Now I have a DSS 12 bolt Hammerhead withj 410 gears. At the very least you should be checking all the 12 bolts that hold the stock driveshaft together. Look for loose or bent bolts.
Old 09-08-2014, 12:43 PM   #8
J-Crazy Camaro
J-Crazy Camaro's Avatar
Drives: Red V8
you might also want to pick up a Drive Shaft loop kit for your V8 from Detroit Speed. just in case your drive shaft does break, it would prevent underbody damage to your ride
J-Crazy Camaro is offline   Reply With Quote
Old 09-08-2014, 04:37 PM   #9
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
Like Keith at BMR said, the main culprits for wheel hop are the Subframe bushings, upper control arms, trailing arms and toe rods. A stiff rear sway bar can also help keep both rear wheels doing the same thing and react similar to a strait axle car.
This is a good suggestion as well.
Feel free to call, PM or email me anytime with questions.
Best regards,
Tyler
888-308-6007
