06-07-2016, 08:11 PM | #1 |
Drives: 2014 ZL1 Join Date: Mar 2016
Cons about 2.5 upper
alright guys im getting ready to order the 2.5 upper pulley, before i do just want to know if i should be expecting any issues after i do this mod. i am bone stock other than full exhaust and CAI. also the stock injectors should be ok for the pulley swap im guessing? i am also going to put an Elite catch can on at the same time.
06-07-2016, 08:35 PM | #2 |
ANGRY Z
Drives: 2015 Camaro ZL1 Join Date: May 2012
A 2.55 will put you at 18% overdriven with stock lower. . Too much for stock injectors.
2015 ZL1 A6 396 stroker RWHP- depends on nitrous
06-08-2016, 10:20 AM | #3 |
Drives: 2014 ZL1- Summit White M6 Join Date: Aug 2014
it is so much easier to change the lower. Just my .02 cents. Also bigger lowers help with belt wrap and reduce the chance of the belt slipping
Anything over 10% needs new injector
750whp @ 13psi Garage Built on Jack Stands.. 850++ 100 shot of sauce
06-09-2016, 08:44 AM | #4 |
Drives: ZL1 Convertible Auto Join Date: Apr 2015
I would only do the upper if you are already planning to disassemble the blower, like to do the isolator or ported snout.
You could do a 5% lower now and when you are ready for injectors do a bigger lower. Also just my .02 cents
LS3 intake and throttle body, Huron Speed Products twin turbo with 6265 oil less turbos, and 3" header back, JRE smooth cam, ID1300, Fore dual 450lph pumps with MSD voltage booster, A6, 305/45/17 MT Street R
06-09-2016, 11:59 AM | #5 |
Drives: 2012 ZL1 Join Date: Nov 2015
The 2.5 upper is a great mod, I did mine because I had to replace the isolater. I have zero belt slip. You will need some injectors though (ID850+).
With Kooks LT (cats), 2.50 pulley, CAI, Injectors mine made 605RWHP / 588RWTQ (SAE) hot with only 20 degrees of timing. It made 15PSI through cats and since then I've removed the cats and it makes 14PSI of boost. http://m.imgur.com/a/j6Nrs Last edited by m1key1111; 06-09-2016 at 12:00 PM. Reason: added |
06-09-2016, 01:06 PM | #6 | |
