11-16-2013, 06:22 PM | #1 |
Drives: 2010 camaro pace car, 2008 cts bl, Join Date: Jun 2011
DSS driveshaft vibration??
I installed a DSS aluminum driveshaft and the car has a vibration at 75 mph and up. It was used but it came from DSS and they checked balance before shipping it to me. When I went to install it I was talking to my tuner and he said a 1 piece driveshaft is prone to vibration, I guess he was right. Does anyone else notice this after installing a 1 piece?
Mods, 2r max cam, ls3 conv,kooks lt w/hf cats,kooks street sleeper cat back with magnaflow res x-pipe, roto fab cai, v-max TB, vigilante 3700 stall, 3.70 LPE, 442hp/392tq, Mike Norris Tune 11.71@116.24 1.63 60' m&h DR's
11-16-2013, 07:03 PM | #2 |
In The Circle
Drives: 2010 Camaro 2SSRS IOM M6 Join Date: May 2009
I have had two different ones from DSS 1 for the stock stuff and 1 for the Hammerhead no vibration. Give them a call I'm sure they will make it right. If your tracking your car it's just a matter of time before the stock one lets go. I have seen the underside of a Camaro where a stock one let go, it's not a pretty sight.
11-17-2013, 02:05 AM | #3 |
I have a DDS driveshaft also in my M6 and it is just as smooth as stock.
I see your in Indiana. Mike Norris did a awesome job of tuning my Ls3 with a V3 supercharger. But he does not like the 1 piece driveshaft. I think he has gotten a few bad ones in. |
11-17-2013, 07:07 AM | #4 |
Yep he is the guy that told me they are prone to vibration.
11-17-2013, 07:57 AM | #5 | |
In The Circle
DSS stands behind there products call them.
11-17-2013, 08:19 AM | #6 | |
Drives: own more cars than i can list Join Date: Nov 2010
when it was installed did you line up the balancing marks. |
11-17-2013, 09:25 AM | #7 |
I didn't do the install, Mike Norris motorsports was doing some converter work on it so I had them install it. So I'm not sure if it is or what your talking about. How can I tell if its installed right?
11-17-2013, 09:28 AM | #8 | |
I'm just trying figure out if its normal and sounds like its not. I'm sure they will help me out I'm just looking for info before contacting them.
11-17-2013, 10:50 AM | #9 | |
In The Circle
11-17-2013, 11:26 AM | #10 | |
I.AM.
Drives: 2011 2SS/RS/A6 cammed-n-whippled Join Date: Oct 2008
The adapter plate that bolts to the transmission has a mark on it, and there's a mark on the driveshaft...those 2 marks should be lined up.
NY5thgen.com
11-17-2013, 12:12 PM | #11 |
Drives: 2010 zr1 Camaro 2011 vert Join Date: Apr 2013
Theres a measurement that needs to be checked to make sure the cv is in the sweet spot.For some reason some cars need a little longer shaft,its rare but weve seen it a few times.Give me a call and I can explain how to check it.Ive been 190 plus with mine many many times with no vibrations.
11-18-2013, 07:33 PM | #12 | |
Untamed Performance EPT
Drives: 2011 2SS Join Date: Aug 2012
Please show picture of balancing marks. Regards
Night Fury Cam
Borla LT Headers and Borla Cat Back ATAK 9in. diff with 4.11's, DSS Axles, and Alum Shaft Hurst Short-Shifter; Ideal Garage Master Cylinder H-E Street Slayer Twin Billet Clutch BMR: Adjustable; Trailing Arms, Toe Rods, Extreme Sway Bar. BMR Subframe Bushings. Strange Rear Coilovers and mounts Tuned by Rhino79 |
11-18-2013, 07:41 PM | #13 | |
Phone number?
Thanks, Scott Quote:
11-18-2013, 08:05 PM | #14 |
Drives: 08' F250 Diesel & 10' Camaro 2SS Join Date: Nov 2010
08' F250 CCSB 6.4L Diesel White & Black, Blacked out, 580RWHP @ 55psi 13.21 @ 101mph
10' Camaro 2SS LS3 M6 White & Black, Blacked out, 684 RWHP & 633 FT.LBS @ 10psi 10.82@130mph TVS2300 ,Hendrix Street Slayer Twin Carbon Clutch, Dana 60 3.73, DSS 1400HP Axles,JRe cam & LaMotta Performance tuned,LPE Fuel, AI Super Chiller,MT ET Streets |
