10-22-2020, 11:42 PM | #1 |
Drives: 2014 Chevy Camaro SS Join Date: Dec 2014
Oil analysis
What's up guys. Just thought I'd share my Blackstone Oil Analysis with everyone. Ive searched and seen other people's reports... I don't know if it's of any concerns especially with my high mileage but the only things that stood out are iron, boron and magnesium. I'm not real sure if these numbers are the norm or not but here are a few specs of my car.
2014 LS3, 86,500k (as of the test), daily driven. Car has full bolt-ons plus 93 octane tune and catch-can. I have used Amsoil full synthetic xl 5w-30 and Amsoil filter, since I bought the car at 2,400 miles. Oil changes/filter are done every 6k miles. Should I be worried about anything? I plan on doing a whole top end rebuild including new heads cam etc this summer. Last edited by jcampos; 01-28-2021 at 10:20 PM. |
10-23-2020, 07:31 AM | #2 |
Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
I would consider changing to a cheaper oil and changer more often and see what happens with the numbers.
10-24-2020, 07:14 PM | #3 |
Fast Cars and Old Guitars
Drives: 2015 2SS RS (L99, baby!) Join Date: Apr 2012
I used to be an Amsoil disciple and still am - to a degree. I actually don’t use it for the extended change intervals. I just feel using GREAT oil and changing it often is key. That said, I am retiring so I may have to rethink the ‘cheaper’ approach and keep my intervals the same. I would support that notion.
10-25-2020, 12:40 PM | #4 |
Drives: 2012 Victory Red LFX Join Date: Dec 2012
Calcium levels are high.
Probably your air filter allowing too much particulate pass thru. Which one are you using?
2018 SS wheels, red Heritage grille, actual driving lights, ZL1 strut tower brace, GM Performance billet aluminum fuel door, front grille Bowtie delete, painted red rotors and calipers, 1/4 window American Flags, splash guards, AEM dry panel air filter.
10-25-2020, 01:03 PM | #5 | |
10-27-2020, 11:31 AM | #6 |
10-27-2020, 11:32 AM | #7 |
10-27-2020, 01:19 PM | #8 |
Yes, a good generally available synthetic like mobile 1, and change at about 3K miles.
10-27-2020, 03:06 PM | #9 |
10-27-2020, 03:20 PM | #10 |
If you want to be more “scientific” about following your numbers then stick with the oil you’ve used and then change oil at 3k and see if those oil analysis numbers cut in half as well. I don’t see what completely changing brand of oil and cutting interval does because then you need to build a completely new baseline of what your engine does with the new oil brand.
When conducting data analysis, you must change as few variables at each given study as possible so you can follow the outcome. But maybe there’s more to it. I digress |
10-27-2020, 03:22 PM | #11 | |
I would just lower your interval and see if that makes a difference. But changing to a different oil when you are trying to make comparisons via analysis isn't helpful imo. For instance, maybe make your next change at 4k miles instead of 6k while using the same oil. This will make the Blackstone comparison much easier to interpret since all base additives will remain the same.
10-27-2020, 04:00 PM | #12 |
I guess it was mostly a backwards way of saying that I feel like running any of the oil in a highly stressed engine 6000 miles is too much and that the only reason to do that is that the oil is too costly to change it more often. Less about the analysis and more about the wear that it indicates.
10-27-2020, 04:27 PM | #13 | |
But it’s not worth throwing expensive oil into a junk engine, if I understand you correctly. He just needs to get to finding out if his engine is junk first? I’ll end up changing my AMSOil with less than 200 miles on it this time, damn covid. Hoping to get at least 201 miles on next oil change. Ha! |
10-28-2020, 11:37 AM | #14 |
I don't necessarily think my engine is junk and I do t want to throw a different oil into the comparison here. I baby my car for the most part and is a true daily driver. I will be changing my oil at about the 4k interval as well as getting the analysis on it. I will report it back to this thread when I do.
