11-27-2021, 10:51 PM | #1 |
Drives: 2011 Camaro 2SS/RS Join Date: Jan 2011
Bleed brakes while transmission is out?
I recently did a reservoir split for my clutch and brakes on my 2011 2SS. I have the transmission currently apart and while I’m waiting for new parts, can I go ahead and bleed the brakes since the reservoirs are split or will I have fluid still coming out of the clutch line that connects, but is currently disconnected, to the slave cylinder?
Thanks
Allen
2011 Camaro 2SS/RS |
11-28-2021, 08:17 AM | #2 |
If you’ve split reservoirs then they are 2 separate systems now. Bleeding brakes will have no affect on the clutch system.
Good luck |
11-28-2021, 10:25 PM | #3 |
Thanks for the reassurance. Now time to bleed the brakes!
Allen
