Old 12-04-2021, 05:52 PM   #1
GMCHRIS98
Drives: Chevrolet Camaro
What break in oil for Ls3 1st start up
Hello im new to this forum , I got a 2014 camaro ss that has 60k miles It accidentally got money shifted and exhaust valves smacked my pistons and bent most exhaust valves except for 3 of them I got new ls3 valves on it and I’m going to be throwing in a btr cam with standard size forged pistons and stock bottom end just got my crank polished now I just need to take my rotating assembly to get rebalanced and a hone with a ball hone, I’m wondering what oil to use for first start up?? I’ve been seeing the people mention the Joe Gibbs Racing Driven BR30
GMCHRIS98 is offline   Reply With Quote
Old 12-04-2021, 06:22 PM   #2
larry_g
larry_g's Avatar
Drives: 2014 1SS/1LE
Driven seems to be doing well for me. I used BR for break-in and then switched for daily use. You can buy a full oil change kit from GPI.
Old 12-04-2021, 07:00 PM   #3
GMCHRIS98
Thanks for letting me know, How many quarts will I need? And ill only be running it for 20 min then swap the oil out to which?
Old 12-04-2021, 08:03 PM   #4
larry_g
larry_g's Avatar
8 quarts, you can run it longer than that.
https://gwatneyperformance.com/produ...#configuration
Old 12-05-2021, 08:37 AM   #5
Joe.G
Joe.G's Avatar
Drives: 2014 2SS/RS 6SP Ashen Grey
20 Min was more for the older engines with Flat Tappets cams and a true break in oil, I still would only run it for say 500 Miles or so and then change it. I don't believe you need a true break in oil with roller cams and what not.
GM 3.91/TrueTrac OEM ZL1 Rims, Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,Remote Clutch reservoir
GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, Moroso Catch Can GC Aluminum DS
Stainless Works Ceramic LTH/HiFlo Cats
SCT X4 Dynosteve,
Hotckis 1" Springs & Chassis Max Brace
BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings
Pedders Radius Rod Inserts Strut tower brace
Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights
AeroForce Dual gauge/Autometer pillar mount.
Joe.G is offline   Reply With Quote
Old 12-05-2021, 11:31 AM   #6
GMCHRIS98
Is this the actual process of breaking it in?
Old 12-05-2021, 01:03 PM   #7
larry_g
larry_g's Avatar
Hard to read on my phone but it looks legit.
Old 12-05-2021, 07:53 PM   #8
Joe.G
Joe.G's Avatar
Sounds like a good Plan.
SCT X4 Dynosteve,
