04-13-2022, 12:08 PM | #1 |
Drives: 2012 2LS Join Date: Apr 2021
Fluid Recommendations
Do any of you have any recommendations for fluids I should use besides the ones listed in the manual? Just want to get the best performance and maintenance I can for my 2012.
04-13-2022, 07:20 PM | #2 |
Drives: 2014 2SS/RS 6SP Ashen Grey Join Date: Aug 2021
I personally use Amsoil 5-30 Signature series Oil, Amsoil ATF Multi vehicle trans fluid for the 6 SP. I was running Amsoil Sever Gear oil but am installing a Tru Trac tomorrow and will be switching to Torcco. Coolant I use AcDelco Dex Cool and Brake fluid I use a couple different types depending.
GM 3.91/TrueTrac OEM ZL1 Rims, Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,Remote Clutch reservoir
GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, Moroso Catch Can GC Aluminum DS Stainless Works Ceramic LTH/HiFlo Cats SCT X4 Dynosteve, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights AeroForce Dual gauge/Autometer pillar mount. |
04-13-2022, 07:42 PM | #3 |
not afraid of the wall
Drives: Camaros Join Date: Apr 2010
I use all the GM stuff as it’s never let me down. I do, however, use Brad Penn engine oil simply because that’s what my engine builder wanted me to use. Still using DEXCOOL, but may be switching to distilled water and water wetter simply because the car is pretty much a track car at this point.
2023 1LE 1SS BCD GCF JF5 MN6 SIA SLN UQT
10/13/22: 1100 Past Camaros: 13 1LE|02 SS|01 Z28|00 SS|91 1LE|91 Z28|89 IROC-Z |
04-14-2022, 08:46 AM | #4 |
Al GM here too, except for the Mobil 1 engine oil, 5w30.. Never any issues to date.
