Old 02-16-2019, 11:48 AM   #1
THE BLACK MAMBA
THE BLACK MAMBA's Avatar
Drives: 2013 Black ZL1
My car is shutting off....this is dangerous
I recently start having problems with my car shutting off while I`m driving...I`ve been lucky so far no cars around and was able to pull over and restart it...what is causing this? any help or ideas is highly appreciated
THE BLACK MAMBA is offline   Reply With Quote
Old 02-16-2019, 12:56 PM   #2
Overflow
Space Shuttle Aficionado
Overflow's Avatar
Drives: 2016 Camaro 2SS
No codes I'm assuming?
Is your car stock?
Old 02-16-2019, 01:34 PM   #3
THE BLACK MAMBA
Is your car stock?
No codes and its not stock... .everything just shuts off
Old 02-16-2019, 02:00 PM   #4
d454brisson
Drives: 2014 ZL1
All power?Just the motor? Any indicators lights?
d454brisson is offline   Reply With Quote
Old 02-16-2019, 02:10 PM   #5
THE BLACK MAMBA
everything goes black...no lights, no power...like turning the ignition off
Old 02-16-2019, 02:20 PM   #6
Overflow
Overflow's Avatar
During the install of your mods... Were any grounds touched?
Old 02-16-2019, 03:05 PM   #7
THE BLACK MAMBA
the only thing new that I installed were drl led lights, the mods have been on the car for 3yrs
Old 02-16-2019, 03:31 PM   #8
Coop[580
Coop[580's Avatar
Drives: 2012 ZL1 Ashen Grey
It’s not the key issue is it?
2012 M6
Kooks 1 7/8, off road pipes , full corsa exhaust ID1300s/ 22% lower / 2.5 upper, JLT CAI, DSX flex fuel, DSX AUX fuel pump. S19 cam
Tuned and built by Speed Inc
635/632-93 octane
725/738-E85
Coop[580 is offline   Reply With Quote
Old 02-16-2019, 04:05 PM   #9
HDRDTD
How old is th ebattery?
Old 02-16-2019, 04:48 PM   #10
THE BLACK MAMBA
the key is off the fob..
Old 02-16-2019, 04:49 PM   #11
THE BLACK MAMBA
I will check the battery tomorrow
Old 02-16-2019, 05:11 PM   #12
hammdo
'It's an experiment'
hammdo's Avatar
Ck all grounds to the engine and to passenger fender - since you stated mods were done...
-Don
747 RWHP 794 RWTQ
Old 02-16-2019, 06:20 PM   #13
THE BLACK MAMBA
-Don
can you give me some locations of the grounds wires to look for?
Old 02-16-2019, 06:37 PM   #14
hammdo
hammdo's Avatar
Back of the heads, passanger head near exhaust, passanger head to passanger shock tower by the fuse box.
I'd start there, then ck battery connections, fuse box power terminal.
There is also power terminal on the driver's side shock tower you'll want to ck...
-Don
747 RWHP 794 RWTQ
