09-22-2010, 12:53 AM | #1 |
Drives: 2010 SIM 2SS/RS MONSTER Join Date: Aug 2009
JUNKMAN take a look inside
first let me say i am a huge fan of your work .
second i bought a pc 7424 and im teaching my self along with your awesome videos how to polish and detail . butttttt ..... i cant seem to not get swirl lines in the paint i am using on speed 5 and a very slow movement in a up and down and then follow with a side to side ! but when im done with the polish and i rub off excess i have a couple of lines . is this normal and the wax will get rid of it or WTF am i doing wrong ??? i am sure its hard because your not here to see it but any advice would be appreciated ! thanks and once again im a huge fan of the skills you posses
HP MONSTER' SOUTHERN CALIFORNIA BUILT, LMR CAI, CUSTOM GRIND CAM, CUSTOM BUILT CNC PORTED AND POLISHED HEADS, FAST 102MM INTAKE MANIFOLD,ARH LONG TUBES AND HIGH FLOW CATS, BIGGER INJECTORS, VALVES SPRINGS RETAINERS, MGW SHORT SHIFTER, EIBACH SPRINGS, FACTORY CHROMED WHEELS, BLACKED OUT EMBLEMS, BLACKED OUT ROOF,BLACKED OUT MARKERS, 3.5 INCH ELECTRONIC CUTOUTS, FLOWMASTERS, ZEX WET 150 SHOT, FOR A GRAND TOTAL OF =630 REAR WHEEL TORQUE ,AND 600 REAR WHEEL HORSEPOWER
MY JOURNALhttp://www.camaro5.com/forums/showth...02#post2023802 SOON TWIN TURBO SETUP |
09-22-2010, 01:02 AM | #2 |
here is a couple of progressive pics i did of my mothers car clay bar ,polish ,polish and then wax. and i must admit its not bad for not using a swirl remover/and im an amateur.. but i still get those lines
but you cant see them in this pic but i think you know what im talking about
09-22-2010, 01:05 AM | #3 |
OKCamaros
Drives: 4 banger Diesel Join Date: Mar 2010
IMO looks good!
except for the first pic tho. |
09-22-2010, 01:09 AM | #4 |
thanks geeo ! yah the first pic is how her paint looked before i touched it and all those horizontal lines are scratches from a dirty mit or something from the local car wash machine .....
09-22-2010, 01:12 AM | #5 |
OKCamaros
those car wash machine is a nightmare for cars! lol
09-22-2010, 01:17 AM | #6 |
09-22-2010, 03:02 AM | #7 |
Drives: The shiny ones. Join Date: Mar 2010
What products/pads are you using?
Also how many passes have you done? I see a noticeable improvement from the first shot to the last so you are making progress. |
09-22-2010, 03:11 AM | #8 |
well i bought a pc at a local detailing shop called 3d imaging ( they also knew of adams product...which was cool ) and the pc came with a little 8 oz bottle of 3d imaging polish and one of wax .the pads are also theirs and both pads are recommended for each product. but i cant seem to get rid of the swirl lines .
09-22-2010, 09:35 AM | #9 |
Master of All Things
Drives: '20 Corvette Stingray Join Date: Jul 2009
What you need to do is first wash the car using DAWN to remove EVERYTHING off the car, use the two bucket wash method. Do the BAGGIE TEST, then clay the car if or where needed. THEN since you have the PC now, you need to get Adams Swirl and Haze Remover, Maching Polish, and Machine Wax. First, watch all the videos from Junkman. Then start with the Swirl an Haze Remover, do the WHOLE car at each step. then the Machine Polish, then the Machine Wax. this will solve your issues.
09-22-2010, 09:40 AM | #10 |
I googled but came up blank on "3D Imagaing Polish". Theres 3D Products, who make the HD car care line in Santa Clarita - is that who you went to?
If they only gave you one "polish" and one "wax" then the polish is likely only a finishing product, a good paint correction process is gonna be 2 stage... a more aggressive product to remove the swirl marks and a finer polish to restore gloss and remove any artifacts left behind by the first product. THEN you'd apply a wax to protect the finish. |
09-22-2010, 01:48 PM | #11 | |
09-22-2010, 08:20 PM | #12 |
anyone else care to drop a line ???
09-22-2010, 08:27 PM | #13 |
I have no life
Drives: 06' Subaru STI, ex-Camaro V6 LLT Join Date: Apr 2010
Dylan is right... you need at least 2 steps in your polishing process... the stuff you are using probably isn't strong enough O_o. Goodluck
09-22-2010, 09:14 PM | #14 |
yah i just picked up a stronger polish today and i will try it soon . after i use the stronger then do i have to use the light and then the sealant ?
Similar Threads | ||||
Any hints on how to remove nuts from inside trunk lid? | OHIOSS | 5th Gen Camaro SS LS LT General Discussions | 25 | 06-09-2010 10:49 PM |
Inside Line Burnout Contest: SS, R/T, GT | DGthe3 | Chevy Camaro vs... | 133 | 05-27-2010 03:20 PM |
Cleaning inside rim | HaZe_X | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 19 | 03-12-2010 02:19 PM |
Adam's Polishes and Junkman Rock!!! | mikey8 | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 8 | 02-27-2010 05:06 AM |
CGM SS/RS #17571 Delivered!!! Review inside, CAUTION... LENGTHY! | JDBeck23 | 5th Gen Camaro SS LS LT General Discussions | 6 | 06-24-2009 07:30 AM |
