09-01-2017, 08:51 PM | #1 |
Drives: 2010 2SS/RS Join Date: Dec 2009
Oil Change Using RP 0w-40
Well I changed my oil the other day an decided to step out a little bit since the motor is now over 50K, I bought 8 qts of Royal Purples 0W-40 with a K&N Filter. So short term I'm impressed 85 degree day running 80-85mph at 2200'ish (3.91s)my oil temp was just a tick above 230-240 and was running 45-50 psi for a prolonged period running down the interstate. Prior to this I was running Royal Purple 5W-30 and at same speed and rpm an outside temp it was 35-40 psi at almost 250 on temp. I set the cruise control to keep it steady, so I hope this is a good thing, I know you have to have some heat in the oil just like anti freeze but what is to cool on oil?? I'm thinking about adding a oil cooler and high pressure/volume pump (nit sure which one)to the car for track days because I saw 260 for oil temp (5w-30)at NCM and Camarocross during C5 Fest this year, I'm not that good but do think I'm getting some what better each time I run there, so I wanna get ahead of the game to keep the temps down.
Orange Krush II
09-01-2017, 10:16 PM | #2 |
Resident nomad
Drives: 2014 Summit White 1SS/1LE Join Date: Nov 2015
I've seen 270+ (digital only goes to 270) during track days with RP 5w-30. I will be adding a cooler here soon.
Sold:
2007 Z06 2002 Viper GTS/ACR 2003 Z06 1965 FFR Cobra 2012 Nissan 370Z ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing. |
09-17-2017, 02:18 PM | #3 |
Drives: '15 SS 1LE, '69 Z28 drag car Join Date: Dec 2009
