Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums -
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - > Engine | Drivetrain | Powertrain Technical Discussions > V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6)
Old 11-14-2017, 09:02 AM   #1
gm2376's Avatar
Drives: 2010 Black 2ss Camaro SS
trans cooler?
So I am going to be installing a 3400rpm single disc lock up stall, and want to add a trans cooler. Looking at two, the adm and the B&M super cooler. I know people like the adm, but how is the B&M? is the ADM worth 3x's as much?
ZL1 10 spokes, Vigilante 3600 Triple Disc TC,Ported Heads, Rod Mod Intake, Comp Stage 3 cam, 25% Underdrive Pully, Pfadt Springs, Pfadt front and rear sway bars, Roto Fab Cai, SW Long Tubes no cats,Bo White Throttle Body, Dr Phil Tune,GHL Cat back, AAC Side markers, 20% Tint all around
gm2376 is offline   Reply With Quote
Old 11-14-2017, 09:10 AM   #2
Abelardoo_12's Avatar
Drives: 2011 camaro ss convertible
The adm is a small B&M, only reason is 3x as much is because it comes with everything needed to install and the connections are the same as the oem so it makes for an easy install. I personally wasn’t too happy with it because my trans still gets way too hot than what i was expecting, I’m thinking about just swapping to a bigger B&M cooler.
I dont know about the B&M super cooler but if its a bigger one than the adm then I would go that route and just find the connections and hardware needed for it.
Abelardoo_12 is offline   Reply With Quote
Old 11-14-2017, 09:35 AM   #3
frankwjr's Avatar
Drives: 2010 SS 2SS M6
if I had an auto....
2010 SS 2SS M6-Spectre CAI-JET TBS-JBA Shorty Headers-ARH H/F Cats-Doug Thorley axle back-MSD 12v coil harness mod-PAC 1218's-BTR 3/8 7.4 push rods-Powell Machine bronze rocker bushings-Prothane motor mounts-Prothane rear sub-frame inserts-BMR Trailing Arms & bushings-1LE 3.91's-1LE axles-Ford S-spring posi-mod-Tune by RDP dynoSteve!(Woot)-Daily Driver-118K!-12.7 at 112-1.9 60'(3.45's)-BFG Comp-2 Street Tire-stock size on ZL1 reps(20x8.5)(20x9.5)-DR's Nitto NT05R(305/45) on Motegi MT120 18x9.5-12.1 at 114-1.7 60'(3.91's) All work by me...
Old 11-14-2017, 03:25 PM   #4
'It's an experiment'
hammdo's Avatar
I went bigger.
Start at post 1702.
Have the ADM Kit, add the bigger B&M cooler, still not enough, then went to Tru-Cool 40k...
I road race my auto...
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." -Enzo Ferrari
See My Build:
hammdo is online now   Reply With Quote
Old 11-14-2017, 05:16 PM   #5
Joe M 2012 2SS
Joe M 2012 2SS's Avatar
Drives: 2012 2SS
I have the B&M 70264 super cooler with a 3200 Circle D converter. My transmission never gets over 180* in stop and go traffic, or after 1/8th mile runs at my local dragstrip.
Roto-Fab intake, SW 1 7/8" LT w/hi flow cats, Flowmaster outlaw exhaust, UDP, 160* stat. Tuned via SCTX4 by Dynosteve at RDP.
Joe M 2012 2SS is offline   Reply With Quote
