01-08-2014, 05:31 PM | #1 |
Drives: 1994 1LE / 2006 Z51 Corvette Join Date: Jul 2009
LG Motorsports ZR28 Wheels
Looking for new wheels for your Camaro? Check out the ZR28 by LG Motorsports.
Features
Be sure to state your a Camaro 5 Member when ordering. |
01-08-2014, 05:40 PM | #2 |
Drives: 2010 2ss/rs & 2014 Stingray Join Date: Aug 2013
Are they Forged like the OE wheels? How much do they weigh?
01-08-2014, 06:09 PM | #3 |
We use a high pressure casting method....to reduce the costs of the wheels to approx 1/2 that of the stock ones. Weight is still within a few lbs of the OEM wheels. Exact I believe to be 32.4 front and 32.9 lbs rear.
01-08-2014, 10:57 PM | #4 |
Drives: 2012 Camaro Convertible Join Date: Jul 2013
Mine look great on my red convertible! Anthony was really helpful and answered all my questions. (Even the stupid ones) I would highly recomend these if you're looking for this style of wheels. I'll try to put some pictures up when I wash my car this weekend!
01-09-2014, 01:53 PM | #5 | |
There is never a stupid question and we are here to help! Can't wait to see pictures! |
01-09-2014, 03:06 PM | #6 |
2010 2SS/RS M6
Drives: 2010 2SS/RS M6 Join Date: Jun 2010
On the website, we're only allowed to buy the 20x10 Front and 20x11 Rear set. Can we do a 20x10 package for all 4? What offset would you recommend for a square setup like that (I'm assuming something in the 25-30mm range) so I would be able to rotate tires?
2/7/2014: 419 hp, 419 tq
Cosmetic: ZL1 front w/mailslot, painted stripes, powdercoated SS rims, tow hook, and full chrome delete Suspension: Pfadt subframe bushings, Pfadt rear UCA bushings, Z28 Upper control arms, Spohn trailing arms with BMR trailing arm & differential bushings, ZL1 Toe Rods and springs, Prothane radius arm inserts & steering rack bushing, Pfadt Sport front sway, FE4 conversion w/ DS rear sway, Pfadt strut brace Drivetrain: RMCR tune, CAI intake, Kooks headers, hi-flo cats & exhaust, VMAX TB, ZL1 fuel pump, LSR Tri-Ax shifter Bumblebee Racecar Build |
01-09-2014, 03:59 PM | #7 | |
To do custom combo's you would have to call the order in. |
01-09-2014, 04:31 PM | #8 | |
Drives: 2013 Camaro 2SS RS LS3 Join Date: Feb 2011
When you say "aggressive", are you referring to the handling? Would the price be the same as tbe staggered set? Thanks!
-2013 Summit White over Inferno Orange 2SS RS- -2014 White Diamond Silverado Z71 Crew Cab Short Box- |
01-09-2014, 04:54 PM | #9 |
Pricing would be roughly the same. By aggressive I mean fitment to the rear quarters. It is right at the edge of the body lines.
01-09-2014, 04:58 PM | #10 |
Oh, OK. Thanks!
01-09-2014, 06:09 PM | #11 |
I'm running 20x10 275/40/20 all corners and no fitting issues
2010 Camaro 2SS/RS | 416 LS3 | FED stage 2 heads
01-09-2014, 06:48 PM | #12 |
Pics?
01-09-2014, 08:08 PM | #13 |
http://www.camaro5.com/forums/showthread.php?t=336184
Go to post 12
01-09-2014, 08:37 PM | #14 |
