10-04-2013, 10:29 PM | #1 |
Drives: 2012 IOM camaro Join Date: May 2013
voltage
Well lately I've noticed that my voltage drops from 14.4 to 12.3 while I start driving and will not go back up to 14 unless u shut it off and restart the engine any ideas of what it could be could it be the battery's going bad? Also I've noticed that when I crank it, it will start super fast to the point were the starter barely finishes it cycle and other times it takes a bit longer to crank. Any help is appreciated thanks.
10-07-2013, 10:48 PM | #2 |
Drives: 2013 ZL1 Blue Ray Metallic Join Date: Feb 2011
voltage
I just noticed this a day or two ago. Haven't had any cranking or running issues either. Interesting to know what you find or if this is normal.
10-07-2013, 11:32 PM | #3 |
Drives: 2011 Camaro SS/RS - 2004 Silverado Join Date: Mar 2010
I think this is normal. The voltage on my car goes up when the voltmeter reads ~12.6 V. This makes me think the alternator is only used when the voltage drops to a certain level.
2011 Summit White Camaro 1SS/RS
-6.2 LS3, TR6060, 3.45, G80 2004 Black Silverado 1500 2WD Regular Cab, Short Bed -5.3 LM7, 4L60E, 3.42, G80 2014 White Caprice PPV -6.0 L77, 6L80E, 2.92, G80 |
10-21-2013, 12:58 PM | #4 |
I haven't taken it to get checked but I forgot to mention I have a sub amp so Idk if that could be why my voltage drops down, do any of you limacharlie or wizzard540 have an amp hooked up? I would think that's why the voltage drops on our cars?
