Old 06-13-2011, 06:53 PM   #1
seddon
seddon's Avatar
Drives: 2017 ZL1
Need some help with steering response
What's up fellas? I have gone though this site back and forth. My car feels good but at high speeds the front of the feels loose almost like the front tires are not on the ground. I like a tight/stiff steering wheel at all times. Any insight on this fix. I will be getting the Zeta Steering Rack & Pinion Mount
I currently have:
1- pedders xa coilover
2-pedders solution b sway bars
3- pedder camaro street 1 package ( rear subframe inserts and front radius insert)
seddon is offline   Reply With Quote
Old 06-13-2011, 07:44 PM   #2
camaro4mybday
"Camaro Joe"
camaro4mybday's Avatar
Drives: 2010 SILVER ICE 2LT/RS CAMARO
Send a message via AIM to camaro4mybday
You can try stepping up to a full bushing in the radius rod but unless you are goin for some track time I'd stay with the bushings you have. How are your xa's set
camaro4mybday is offline   Reply With Quote
Old 06-14-2011, 03:54 PM   #3
tortop45
Drives: 2ss
hi my 2ss felt like that,its the front lower control arm bushes they are to far week for the job,get on to pfadt and use part no=1410113 ,cost about $95.00 .my car felt like that from new.now it feels safe !!!!!! the rack mounts are ok.
tortop45 is offline   Reply With Quote
Old 06-14-2011, 05:05 PM   #4
Rob@WretchedMS
Drives: His Wife Crazy
Do you have a print out from your alignment?
Rob@WretchedMS is offline   Reply With Quote
Old 06-14-2011, 06:01 PM   #5
seddon
seddon's Avatar
Drives: 2017 ZL1
Rob you did my alignment and the cars drives great with my stock wheels but with my 22's the steering wheel feels sloppy/loose at high speed.
Old 06-14-2011, 06:06 PM   #6
seddon
seddon's Avatar
Drives: 2017 ZL1
Xa's are beautiful very close to stock with my 22's on.
It's weird because with stock wheels the car is good but with my 22's I don't feel comfortable at high speeds. I will look into it.
Old 06-14-2011, 06:23 PM   #7
Rob@WretchedMS
what is your tire pressure,
what make and model of tire?
forgot that i did that, lol
Old 06-14-2011, 07:25 PM   #8
seddon
seddon's Avatar
Drives: 2017 ZL1
That's ok you guys do a lot of camaros
I have perilli p zero neros 315/25 rear and 265/30 front tires pressure is set at 37 psi
Old 06-14-2011, 07:56 PM   #9
Rob@WretchedMS
and they didn't touch the alignment when you had the tires put on correct?
Old 06-15-2011, 05:27 AM   #10
seddon
seddon's Avatar
Drives: 2017 ZL1
That's correct rob nothing was touched. It's weird last week when I had the stock wheels on they were fine.
Old 06-15-2011, 07:11 AM   #11
n116ebo
n116
n116ebo's Avatar
Drives: 2010 2SS YELLOW TRANSFORMER AUTO
Wish I had an answer for you, but do not. I had my stock tires and rims up tp 136 mph one time and was really impressed how smooth the ride was, no vibration and good front end control.
n116ebo is offline   Reply With Quote
Old 06-15-2011, 08:24 AM   #12
Rob@WretchedMS
it must just be the extra weight of the 22" rims at speed.
Old 06-15-2011, 10:28 AM   #13
seddon
seddon's Avatar
Drives: 2017 ZL1
Actually my 22's weigh less than stock wheels. But I think I know what the problem is gotta do some testing and will let you guys know.
Old 06-15-2011, 12:06 PM   #14
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
Please keep us posted.
Another DSV First! Custom Premium DStyle Steering Wheel For Camaro (Pictures Inside) dsvcustoms Interior Parts & Accessories 38 08-19-2010 11:27 PM
The leather is cracking/peeling on steering wheel #2 Alarick Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 38 07-01-2010 01:15 PM
A long response to fbodfather's question... Ravirn 5th Gen Camaro SS LS LT General Discussions 57 06-19-2010 06:19 PM
Steering wheel leather cracking!! meliss7567 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 5 09-17-2009 02:13 PM
Power Steering - hydraulic or electronic steering? balonywolf 5th Gen Camaro SS LS LT General Discussions 20 02-28-2008 11:01 PM
