04-21-2010, 12:17 PM | #1 |
Drives: 2LT/RS Join Date: Jul 2009
***EIBACH KIT QUESTION** URGENT
Hey guys, so i installed my eibach kit last wkend, and got an alignment, all was great except everytime i turn left now, the spring is rubbing and clunking? yes i used the right ones on the front, checked the seating and it looks ok....but does it matter what front spring goes on which side, thanks a ton!
-JON |
04-21-2010, 12:25 PM | #2 |
12.23s@113mph
Drives: 2SS/RS, A6, just a few bolt ons Join Date: Jul 2009
it shouldn't matter which side they are on. do you think maybe you forgot to put the brake or speedometer line back in place?
RIP Cammie 7/15/2009 - 4/1/2011 |
04-21-2010, 12:25 PM | #3 |
Drives: '69 SS Convertible Join Date: May 2009
I would call Eibach.....let us know if you hear something.
I'm about to install some drop springs so things like this really concern me.
Build Journal |
04-21-2010, 12:26 PM | #4 |
hmmm... everything tight on the strut assembly? is the spring seated correctly? check the strut cap maybe.
04-21-2010, 12:28 PM | #5 |
04-21-2010, 12:28 PM | #6 |
cool thanks for the ideas guys...im bout to jack it up and see what the prob is...i'll post in a few hrs, thanks for some leads..
-JON |
04-21-2010, 01:52 PM | #7 |
Hope you find out what the cause is. Have a couple hundred miles on mine now with no issues at all, except finding routes without speedbumps....
Good luck |
05-10-2010, 11:37 AM | #8 |
Drives: 2020 2SS Conv Join Date: Sep 2009
Hi, I just installed the Eibach as well, and also have an additional "clunk"...strangely enough also sound like it ofn the left although not necessarily when turning. Did you fiind out what was causing your noise?
05-10-2010, 12:12 PM | #9 |
nah brother never figured it out...but the sound went away quite a bit..maybe just needed a lil break in i dunno...anywho i think its the crappy stock endlinks...so i ordered pfadt endlink front/rear and will be putting em on this wkend..
12-06-2010, 01:11 PM | #10 |
Banned
Drives: Car Join Date: Jan 2010
Eibachs
I just got my camaro back and have the same noiseThe mechanic took it for a ride along with the service manager took it for a ride and assured me it will be okay? I'm hoping my noise will dissappear now?
12-06-2010, 01:42 PM | #11 | |
Drives: Camaro Justice Join Date: Jun 2007
Please tell me about your noise. When does it occur? What does it sound like? OE or aftermarket wheels? Did you have it before you lowered? |
12-06-2010, 10:49 PM | #12 |
Banned
It occurs everytime I turn left! It's a fairly loud noise! I have factory 19 inch rims and no noise before I lowered?
12-07-2010, 06:56 AM | #13 |
Similar Threads | ||||
Official Victory Racing Turbo Kit Post | VictoryRacingEngines | Forced Induction | 44 | 07-26-2010 01:45 PM |
Double Din Kit Stock Appearance Taking Orders | Hess RS | Audio / Visual / Electronics/ Gauges / Nav | 30 | 03-14-2010 10:41 PM |
ULTIMATE PERFORMANCE* TURBO Camaro SS -- 750hp Custom Single Turbo Kit (T04Z) | Ultimate Performance | Forced Induction - V8 | 496 | 10-11-2009 01:29 PM |
5202 (H16 ; 9009) Slim HID Kits !!! 09-Up Camaro Fog Light HID kits !!! | HID_Guy | Exterior Parts & Accessories | 19 | 09-08-2009 01:07 AM |
2010 Camaro Fog/DRL Light 5202 HID kits .... | HID_Guy | Exterior Parts & Accessories | 1 | 09-07-2009 12:19 PM |
