04-03-2015, 04:06 PM | #1 |
V1 with Savy and V1 connection
I was looking for some advice about installing all of this together. It appears that I must use the OBD port for Savy and that would power the v1. With v1 connect installed as well where do you recommend I mount it?
I have a blendmount on the way and I know the mirror tap is out. So for those of you that have elected to run the flat power cable up or along the headliner and down the A pillar what advice or tips on installing do you have. I don't want to mess anything up and hate rattles. Thanks
Laus Deo
04-11-2015, 11:48 AM | #2 |
does anybody have a like for the a piller removal to run the wire I dont want to mess anything up
Laus Deo
05-15-2015, 08:49 AM | #3 |
Drives: 2013 AGM ZL1, Porsche 914, '81 GMC Join Date: Feb 2012
I have a V1 and also use radar projector, which also plugs into OBDII. The flat cable tucks nicely under the headliner and pillar without having to remove anything. Pop off the door sill, the piece by the dead pedal and the fuse cover and you'll be able to route the cable and secure it to prevent rattles.
Thread Tools | |
