02-25-2011, 12:58 PM | #1 |
Sway Bars
Anyone install sway bars themselves? If so, how difficult was it? If not, anyone now a good shop in Austin that could do the install?
Thanks, Dave
2G1FJ1EJ8A9173456
1SS CGM w/ Black Stripes L99 3/14/10 |
02-25-2011, 02:17 PM | #2 |
Drives: 2010 CAMARO ABM 2LT Join Date: May 2009
I did my rear sway bar myself. with help from my son working one side with me working the other. It was very very easy. about 5 minutes tops once we got started removing the bolts old bar and installing the new one. one person could do it, but it would take much longer obviously and be just a little more difficult. still managable, go for it!
02-25-2011, 02:19 PM | #3 |
The front sway bar takes a little work getting it out and new one back in (you have to hold your mouth just right), but once you figure it out, it comes right out.. The rear was a breeze !!
02-25-2011, 02:25 PM | #4 | |
Drives: 89 IROC 350 Join Date: Mar 2009
Seriously, it's not bad... IF you get bound up and just can't get it out, put a floor jack under the oil pan with a piece of wood to protect the pan, loosen the two front motor mount bolts (do not remove) and jack the engine up a couple inches. It will come right out then. I've installed probably 10 sets and only had to do that once, on the only 2011 I did. Good luck! |
02-25-2011, 02:38 PM | #5 |
Thanks for the responses guys! Looks like I'll be starting with the back.
2G1FJ1EJ8A9173456
03-01-2011, 09:05 PM | #6 |
Drives: '13 Avalanche & 2018 1SS/1LE SW Join Date: Sep 2010
What make of sway bars did you install? How did it go? I did many sets on the 4th gens I used to have but this 5th gen looks kinda tricky in the front.
Similar Threads | ||||
5th Gen Suspension -- The Book | JusticePete | Suspension / Brakes / Chassis | 151 | 05-07-2015 05:52 PM |
Better Handling | Tbanks | Suspension / Brakes / Chassis | 30 | 12-15-2010 11:50 AM |
Hotchkis: Tuned Suspension Setups | Springs | Chassis Brace | Sway Bars | FREE S&H | AJ@ECSMotorsports | Suspension / Chassis / Brakes | 80 | 11-17-2010 02:28 PM |
