08-25-2013, 06:34 PM | #1 |
Drives: 2010 Camaro 2SS/RS LS3 IOM Join Date: Aug 2012
Leak?
Hi,
So I noticed some fluid around my rear drivers side rim today. I wiped the rim off but noticed it was also wet on the inside of the rim. Any idea what this could be?
08-25-2013, 06:52 PM | #2 |
ex-RCAF
Drives: 11 SGM1LTRS SV1000S Join Date: Mar 2011
could be brake fluid?? or a leaking axle seal.
08-25-2013, 07:02 PM | #3 |
Dog pee?
08-26-2013, 01:19 AM | #4 |
Damn, I hope not. Would this be covered under the drivetrain part of the warranty?
08-26-2013, 01:20 AM | #5 |
08-26-2013, 02:02 PM | #6 |
10-bolt Destroyer
Drives: 2012 Camaro 2SS/RS - AGM, LS3/6M Join Date: Jun 2012
Its not axle fluid. Its on the wheel side so it's either Brake fluid or the shock fluid is leaking out of that shock.
2012 Camaro 2SS/RS - LS3/TR6060: Cam, Headers, Exhaust, Intake, Gears, Twin Disk, Suspension, Tuned - 475rwhp, 443rwtq |
08-26-2013, 04:00 PM | #7 |
Any idea if this is covered under "powertrain warranty"? Anyone?
08-26-2013, 04:38 PM | #8 |
Drives: 2012 Camaro 2SS/RS IOM Join Date: Oct 2012
Doesn't hurt to take it in to have it looked at regardless.
08-26-2013, 08:05 PM | #9 |
Yep, I'll get it looked at, but my brother-in-law is an ex-GM mechanic, so I'll have him look at it first. If its covered, then I'll take it to the dealership.
Someone mentioned it might be the caliper that's leaking?
08-26-2013, 08:13 PM | #10 |
Drives: 2010 Camaro 2SS/RS SIM Join Date: Apr 2009
How do your brakes feel? That is my initial thought...brake fluid. Definitely not diff fluid. Or do you have a CV boot leaking? Depending on the temperature, it can appear oily if grease is leaking. If it was a strut leaking that bad, that corner would be quite bouncy.
08-26-2013, 08:14 PM | #11 |
hrm, haven't really noticed anything out of the ordinary. I just got back from vacation on Friday, and drove it a lot on the weekend (cuz I missed it lol).
I texted my brother-in-law, and he suggests not driving it until I get it checked too! grrrrrrr
08-26-2013, 08:17 PM | #12 |
I have to agree with your brother-in-law. Better safe than sorry.
08-26-2013, 08:27 PM | #13 |
what is a "CV boot"? Sorry I'm mechanically an idiot.
08-27-2013, 12:50 AM | #14 |
It is the rubber boot that covers the constant velocity joints at either end of the axle. Typically they will sling grease all over the wheel and inner fender, but I have seen them with pin holes which can look like a small leak.
