06-13-2012, 09:02 AM | #1 |
Drives: 2018 Camaro SS HotWheels Edition Join Date: Oct 2009
AC Condenser removal
Anyone out there done any ac work yet? I need to replace the condenser on the front of the radiator and was wondering if its possible to do without disconnecting everything and pulling it w/ the radiator. From some stuff I've found it looks as if you can unbolt the top of the radiator and tip it back, giving you access to remove the condenser bolts and remove it. Can anyone confirm this? Just wondering how difficult it would be to do myself as opposed to paying $700 for the dealer to replace the $100 part. Thanks!
06-30-2012, 11:36 AM | #2 |
unbolt+tip
07-01-2012, 09:37 AM | #3 |
You will save yourself some time and frustration if you remove the fans and radiator. They come out easily within minutes. The condenser mounts to the radiator and has a integral power steering cooler. Easiest way is to remove all together.
07-02-2012, 05:31 PM | #4 |
I just did mine today in like 20 minutes without removing radiator. Very easy
07-03-2013, 07:15 PM | #5 |
Drives: 2010 Camaro SS Join Date: Jul 2013
I just bought one off ebay for less than $65. I went down to my local mechanic and he told me he refuses to install this part unless I buy it through him. I asked him how much he would charge for the part and he said his cost was $270 and he would charge me $330 and 1.8 hours labor. Looks like I will learn how to install it myself. Seriously! Why such a mark up for the same part? And don't even try to say the quality difference, because if that was the case the original condensors would not be failing in so many of our camaros.
BTW. First post. Just bought the car in the middle of a 95 degree heat wave and found out the condensor had a hole in it. Oh well, still a nice car. |
07-07-2013, 08:24 PM | #6 | |
Drives: 2010 camaro ss Join Date: May 2009
07-15-2013, 03:12 PM | #7 | |
07-15-2013, 03:15 PM | #8 |
I am, however, going to replace the stock grill with an aluminum billet grill so maybe it will deflect any incoming projectiles better.
