11-20-2013, 03:18 PM | #1 |
2010 2SS/RS M6
Drives: 2010 2SS/RS M6 Join Date: Jun 2010
Coating exhaust tips
I'm getting a new Kooks exhaust system (LT's, cats, & catback) which unfortunately comes with polished chrome tips. My car does not have a speck of chrome on the outside of it (all been either removed, painted, or powdercoated) and I want the exhaust to match. I would like to address it before it's installed so I'm not dealing with the diffuser or overspray issues.
That being said, I have a couple questions for refinishing the tips: 1) What is the recommended way to get them black (preferably matte black)? Powdercoating, rattlecan spray paint, plasti-dip? 2) Would this "customization" cause any issues with the lifetime warranty from Kooks? |
11-20-2013, 03:52 PM | #2 |
Drives: 2012 Camaro 1ss Join Date: Jun 2012
My friend owns the shop I had my ATAK exhaust installed. We acutally sanded the chrome from the exhaust tips and painted it with a matte black heat resistant paint. I forget now the name of the paint, but it was something that could be bought off the shelf. We applied a total of 3 coats so I had to wait and extra day or 2 before installing the system but the look was defanitley worth it. Almost 2 years and not one sign of color fade or flaking of paint. If you want I can look up the paint, and post some pictures up how it turned out. Hope this helps in some way .
11-20-2013, 03:59 PM | #3 |
2010 2SS/RS M6
^^^ That would be awesome. Any/all suggestions are welcome!!
11-20-2013, 04:02 PM | #4 |
Drives: E92 BMW M3 Join Date: Oct 2012
Be sure you do as BH531SS did and sand the chrome, you dont want to skip that step as paint wont stick to chrome for long.
SOLD - 2013 1LE - Pat G Spec'd Cam, NPP with 1 7/8" Long Tube Headers with High Flow Cats, Intake w/scoop, Ported Throttle Body, and Apex 1.25" Lowering Springs.
J-Rod Built and Matt@FSP Tuned |
11-20-2013, 04:05 PM | #5 |
[COTW 5/12/14]
Drives: 2012 CRT NF Cammed 2SS/RS For Sale Join Date: Oct 2011
Powdercoating would be your best bet probably, double walled bigger tips dont get all that hot, and powdercoating cant stand a lot of heat, wont hold up forever on headers, but exhaust tips arent nearly as close to the heat source.
As for the tips, they are just metal, so the warranty probably covers the finish, which you will be painting over anyway. HI temp ceramic paint or coating is also an option. You can plasti dip them to make sure you will like the look, then take it off after. But I think plasti dip will hold up to the heat. My tips get hot, but not hot enough to melt plasti or anything, which is all plasti-dip is. |
11-20-2013, 05:47 PM | #6 |
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
If money isn't an issue, they have matte black header coating. Probably wouldn't cost a LOT but time could be an issue. Easiest/cheapest method would be the sand, spray with heat resistant paint.
Halltech CF 102 fed GPI modded intake manifold Bo (knows) White ported TB Kooks LT's/ Dynomax VT Pfadted (springs/sways) Dyno tuned by Rhino and GPI I once parallel parked a train. |
11-20-2013, 05:49 PM | #7 |
We send them to Jet-Hot and have them ceramic coated.
11-20-2013, 06:30 PM | #8 |
Ceramic coating is the best option. Powder coating will only hold up to about 400* depending on the powder.
Best regards, Tyler 888-308-6007 |
11-20-2013, 10:30 PM | #9 |
Drives: 2012 ZL1 & 2010 2SS/RS Join Date: Jul 2009
As stated, ceramic is best. The problem with coating catbacks is if the manufacturer does not do it, you have to ship the whole catback to the coater, and to customer, which gets expensive.
11-21-2013, 08:28 AM | #10 |
2010 2SS/RS M6
If I did the sand & high temp paint route, would there be any issues with the Kooks warranty?
