Old 04-06-2016, 08:21 PM   #1
bobby35ny
bobby35ny's Avatar
Drives: 18 ZL1 A10
SuperCharger rattle one week old VIDEO
Turn up the speakers or use headphones..
Maybe I'm too picky?
Rattle at :25 :46 :50 1:21 2:03 2:21 2:27 2:37 2:45 2:56 3:00 3:04
https://youtu.be/DHWz9iLQidk
2017 ZL1 M6 Bog City, 2013 ZL1 M6, 2010 2SS M6
ZL1::J-E-T-S JETS JETS JETS
bobby35ny is offline   Reply With Quote
Old 04-06-2016, 09:01 PM   #2
Candr3535
Candr3535's Avatar
Drives: 2013 ZL1 Triple Black Vert M6 #5591
Me personally, it would be back at the dealership. Making sure they put a brand new supercharger on it and I'd like to see the old one when done. Good luck
695 RWHP / 660 RWTQ @ 13.5 PSI
Dyna-Tech Headers Ceramic Coated w/Super Flo Cats, JRE Custom Rough Idle Racing Cam Package and 125 RWHP Pulley Kit w/ 28% pulley, Custom Tune by Ted, ID850 injectors, JMS Fuel Booster, NGK Plugs, MSD Plug Wires, Roto-Fab CAI, Roto-Fab Big Gulp, Elite Catch Can, Mild to Wild, 90mm VMaxx Ported Throttle Body, Skip Shift Elim., D3 Coolant Resevoir, Separated Clutch Resevoir, and Fuzzy Red Dice..
Candr3535 is offline   Reply With Quote
Old 04-07-2016, 06:12 PM   #3
cvp33
America FVCK Yeah!
cvp33's Avatar
Drives: 2021 ZL1 1LE A10
None of that sounded good.
cvp33 is offline   Reply With Quote
Old 04-07-2016, 11:39 PM   #4
370zyzfr1
Drives: 2014 Camaro Zl1 Tripple Black!
So what did the dealership say?
370zyzfr1 is offline   Reply With Quote
Old 04-07-2016, 11:58 PM   #5
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
Ya, I would be taking that back into them, that's not a normal sound. I am also wondering what the dealership said to you about it.
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 04-08-2016, 08:39 AM   #6
JBZL1
JBZL1's Avatar
Drives: 2012 ZL1
That is definitely not normal! I had mine done at 9000kms, and it wasn't even that bad !
2012 ZL1 preproduction car #13
ROTO-FAB intake / IC reservoir , 2.85" upper , ported inlet
JBZL1 is offline   Reply With Quote
Old 04-08-2016, 09:59 AM   #7
ZMEnow
Drives: ZL1, 2013, tri-coat-red, manual
Hold the camera in the front, snout where the pulley is located.
ZMEnow is offline   Reply With Quote
Old 04-08-2016, 11:01 AM   #8
bobby35ny
bobby35ny's Avatar
Drives: 18 ZL1 A10
Funny you should say that, sound really isn't coming from the front snout area, it sounds like its coming from the rear of the supercharger, like a bearing back there or something. I used a good camera to record, valvetrain and injectors sound pretty loud no? is that normal on the LSA? Even think I hear an exhaust leak.
Going to drive by the Dealer today.
-Bobby
Old 04-08-2016, 09:54 PM   #9
ZMEnow
-Bobby
Valve train and injectors sounds normal for LSA, normal ticking. Get a cheap stethoscope from autoparts store, 20 bucks and place it on the snout and then the supercharger.
Old 04-08-2016, 11:19 PM   #10
bobby35ny
bobby35ny's Avatar
Drives: 18 ZL1 A10
Finally got to the dealer today, I had the shop foreman listen to it, He agreed!!
He said this sounds worse than the old one we took out. He's going on vacation for 2 weeks. Told me to wait until he gets back so he can be around and take care of it, He expects push back from GM so he wants to take care of it for me.
Old 04-09-2016, 09:37 AM   #11
JBZL1
JBZL1's Avatar
Drives: 2012 ZL1
That sounds promising!
Old 04-10-2016, 12:50 AM   #12
hairtrigger
Drives: 69 Chevelle SS396 2013 ZL1
Is it an intermittent misfire going on there? Seems to be shaking sometimes. That will also produce rattling sounds at idle. Just something to look at. You have to watch the whole video to see what I mean. Good luck.
hairtrigger is offline   Reply With Quote
Old 04-10-2016, 10:26 AM   #13
bobby35ny
bobby35ny's Avatar
Drives: 18 ZL1 A10
I get what your saying!
I do seem to believe that the front isolator is not the ONLY problem with the LSA supercharger, I think there is more to it.
On my original supercharger, marble noise came from the front. I took off the belt and felt the slack and knock by hand spinning the pulley. This "New" supercharger sounds like the marble noise is coming from the rear, I also took off the belt and no slack or knock from the front pulley. The original supercharger made the noise cold OR hot. This new one makes more noise as the car gets hotter.
Sounds like the rear bearings are shot in the rear.
-Bobby
Old 04-29-2016, 01:32 PM   #14
bobby35ny
bobby35ny's Avatar
Drives: 18 ZL1 A10
So...Picked up the car today, New Supercharger #2.
Right now, only a few hours old, Supercharger is nice and quiet...
-Bobby
