03-07-2013, 02:49 PM | #1 |
Drives: Burgundy camaro, 1LT Join Date: Mar 2013
Kicker Camaro Coupe Factory Component Speaker Replacement
Ok guys so I am getting this for my camaro. http://www.hifisoundconnection.com/2...KER-UPGRADE-52
How much would it cost for a local dealer at nj to install these. Thanks again |
03-12-2013, 09:06 AM | #2 |
Drives: SSICKO Join Date: Jul 2010
you can install those your self, as long as you have the connectors that the picture shows, then its simple. i just did something similar in my f150, the connector plugs are great and worth it. just look up how to remove the speakers and you should be fine
Slowhawk Performance Built & Tuned
03-12-2013, 09:16 AM | #3 |
Drives: Black '13 2SS/RS/1LE w/NPP/NAV Join Date: Oct 2012
You could also check with Steve at ********.com. He sells all the adapters and whatnot also he puts together some speaker packages.
03-12-2013, 04:45 PM | #4 |
Drives: Black 2011 2SS/RS / Black 2013 ZL1 Join Date: Feb 2012
I recommend you save yourself the money and install those yourself. There are some very good DIY's on this forum that you can use for the installation.
