10-09-2009, 02:55 PM | #1 |
Drives: 2010 Camaro Victory Red 2SSRS Join Date: Oct 2008
Anyone know the format for a playlist on USB drive?
All my files are on the root of the drive (no folders) and the radio can see the songs without any issues. However if I generate a playlist (m3u) the tools that do that put the path of the USB drive when it's attached to my computer. I.e. g:\song.mp3 I've tried all sorts of formats for the playlist \song.mp3, "song.mp3", ..\song.mp3 but nothing seems to work. The radio can see the playlist, can see the song name, but when I hit the button to play a song on the playlist it doesnt do anything, which makes me think it sees the song name but then doesnt recognize the path to the file that the playlist is telling it.
So if someone has succesfully created a playlist that works on a usb drive with the radio could you just post one of the lines from their working playist (change file extension to .txt to read contents, then back to .m3u when you are done) so I can see what works? Thanks |
10-09-2009, 03:22 PM | #2 |
Geek
Drives: IOM 2010 Camaro 2SS Join Date: Oct 2008
Just...
file name.mp3 With a line feed between each. Nothing more. No quotes, directory paths, etc. The files don't have to be in the same directory. It (somewhat surprisingly) finds them. But keep in mind, it will not continue the playlist after restarting the car. |
10-09-2009, 03:40 PM | #3 |
Thanks.
So far that didnt work. I'll keep experimenting but I've tried so many things I'm getting tired of going back and forth between the car and the computer. My test song which is playable if you search by songs has a filename that has spaces and an ' in the filename. I thought maybe one of those was causing the issue, although if the radio can play the song directly I dont see why that same filename format shouldnt work with a playlist. Anyhow I renamed the file to something that didnt have spaces or an ' but that didnt help either..... ugh.. |
10-09-2009, 04:22 PM | #4 |
Drives: 2010 Cyber Gray 2SS Camaro Join Date: May 2009
you can make folders and put the music files in them and use the folders as your so called playlists, then you can just search by folders and play from them
2010 CGM 2SS M6 w/ FM AT Cat back
10-16-2009, 10:50 PM | #5 |
Drives: 2010 Camaro 2SS RS, Black Join Date: Sep 2009
Can someone explaine the BASICS of how the files on the USB will play? Are they alphabetical? If sorted into folders, will a folder play its contents alphabetically, and then move on to the next folder, or are the folders ignored completely?
10-19-2009, 11:58 PM | #6 | |
100% Chevy & Harley Man
Drives: 2010 2SS: Blown LSX 376-B15 Join Date: Feb 2009
Songs are played in the order added to the folder. I put a 3 digit number in front of the song to hold its place in the playlist (001 Back in Black.mp3, 002 Enter Sandman.mp3, etc). The playlist will keep em in order since it sees the number 1st. Right now I have about 7 different playlists with around 200 songs in each. The radio unit has a folder that alphabetically detects all songs from all 7 folders. Nice feature- but I ended up putting wife's country music on a differfent flashdrive since I'd go crazy listening to Metallica, then Carrie Underwood. iTunes can make mp3 versions of songs- you can fit approx 160-200 mp3 type songs on 1 CD (About 695 MB). I use iTunes to create playlists, then burn them to a cd, then copy n paste the songs on the cd to a folder on the flashdrive. One folders name (for ex) is #1 Killer Camaro Tunes. This folder will show up on top first because of the #1.
LSX 376-B15, TVS2300 SC, Harland Sharp Rockers w/ Trunion Bearings, ATI Balancer/keyed, AR LT Headers/Borla Catback Exhaust, DSS 1400 HP Axles, DSS aluminum driveshaft, 3.70, Hotchkis Springs/Sway bars, Forgeline SO3P Aluminum Wheels (20x9.5 F/20x11 R)w/ Hidden Titanium Hardware, Nitto NT05 Tires (27540ZR20 F/31535ZR20 R), Billet LPE brake/gas pedals, Escort 9500ci Radar Detector Laser Jammer, Roto Fab CAI with Ice Silver box, Carbon fiber tube/MAF Housing Assy, LPE Aluminum coil covers, SS9 Sleeper Fiber Glass Hood (ACS), Carbotech 1521 ceramic brake pads, Elite catch can.
10-21-2009, 06:02 PM | #7 |
Donkey Dick Cam Camaro
Drives: 2010 2SS/RS LS3 M6 Join Date: Oct 2009
Im barely gonna try the usb thing tonight.
its supposed to read .wma and .mp3 as well a lot of my music is .wma (because you can rip an original CD into lossless bitrate .wma files) so i was very happy with it. im celebrating my 10 day anniversary with my 2010 tonight |
10-29-2009, 05:04 PM | #8 |
Drives: 2010 2ss/rs Join Date: Sep 2009
this is gonna be an stupid ? but im not very good with computer stuff , are you guys gettin one of those usb flash drive things and storing the music to it then leaving it in the usb slot and playing music off that or are you able to store the music to the radio?
10-29-2009, 05:19 PM | #9 |
Geek
You leave the flash drive in the USB port. The radio has no storage for music.
10-29-2009, 05:25 PM | #10 |
how big of a usb do you recommend getting? im going to do this becuase i dont like having my iphone cord pinched up in the console
10-29-2009, 08:12 PM | #11 | |
Geek
But it all depends on how much music you have. But due to the 2500 song limit, I'd say no larger than 16gb. |
10-29-2009, 08:14 PM | #12 |
i just dont like the cord getting all pinched up when the consoles closed, i dont even have 2500 songs so that would be the way i need to go
10-29-2009, 08:51 PM | #13 |
Geek
Get a 2nd iPod used or something? It remembers the the last playlist, random setting, etc and doesn't need to index every time you start the car.
10-29-2009, 08:57 PM | #14 |
so usb is like a last resort ipod/phone better ?
Similar Threads | ||||
Thumb Drive USB issue | Coop 2010 | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 55 | 12-16-2009 02:29 PM |
This is why I dont let other people drive my car | Phoenix328 | 5th Gen Camaro SS LS LT General Discussions | 117 | 09-30-2009 06:30 AM |
For USB thumbdriver users - save your USB connector | rObOtOm3000 | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 8 | 09-29-2009 12:44 AM |
Issues with USB Flash Drives | daniel@txangl.com | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 18 | 06-29-2009 07:18 AM |
Microsoft working with automakers. | TAG UR IT | General Automotive + Other Cars Discussion | 11 | 02-23-2008 01:21 AM |
