11-21-2012, 08:37 PM | #1 |
Drives: 2010 Camaro 2SS/RS Join Date: Sep 2009
Identify this connector
When I was installing the oil feed lines for the turbos I ran into a connector that was not being used. It foes on the passenger side wiring harness that runs the injectors and coils and ends with this connector.
What is this connector for?
2005 Dodge Ram 2500 RCSB Thunder Road Hemi Sport w/STS Turbo
2004 Dodge Ram SRT-10 - Silver - Stock 2003 Chevy 1500 RCSB Stepside 400SS - 408 in now awaiting Turbo |
11-21-2012, 08:53 PM | #2 |
Drives: 2012 45th Vert, 2011 4x4, 9sec Vega Join Date: Mar 2012
I didn't pull mine for a Maggie but I think it plugs into a sensor on the side of the engine block at the back passenger side. Knock sensor or reluctor pickip?
I feel it only fair to warn you, I have a black belt in CAPS LOCK.
11-21-2012, 09:02 PM | #3 |
Drives: Anything Blown Join Date: Aug 2010
MAP sensor?
11-21-2012, 09:08 PM | #4 |
the MAP sensor goes in the front of the intake this connector was between the passenger head and the firewall. I saw it there when I first installed the turbos and again recently when I pulled the motor out and reinstalled everything. Maybe it is an stick thing and the autos don't need it.
11-22-2012, 08:15 AM | #5 |
Drives: 2010 SS Join Date: Jul 2011
Looks like the plug for AFM that goes to the back of the valley cover. Is this a L99 with AFM removed?
2010 2SS
TVS 2300 w/ OD Cog & 3.0 pulley,Maggie Max Stage 2, Innovators West 10%OD 8 rib kit, 3500 stall converter, JRE Rough Idle Blower Cam, Dynomaxx Headers, ID-850 Injectors, LPE dual fuel pump, CAI Intake w/ race scoop |
11-22-2012, 08:29 AM | #6 |
Drives: 2010 camaro ss Join Date: Nov 2012
I do not have that connector on my LS3 harness.
11-22-2012, 08:43 AM | #7 |
http://www.camaro5.com/forums/showth...=257877&page=4
Check out post #95. That's where this should plug in unless you removed AFM.
2010 2SS
11-22-2012, 09:30 AM | #8 |
SIP
Drives: 2011 1SS, L99, A6 , Silver Ice Join Date: Aug 2010
That is for the AFM connection that is on the cover. I did the delete and used the LS3 cover. Taped the connector out of the way, no longer used.
"My Birthday gift from my wife on 10/19/2010 "
11-22-2012, 09:39 AM | #9 |
Drives: 2010 Camaro SS\RS Join Date: Jun 2012
11-22-2012, 09:45 AM | #10 |
Drives: Has Wheels Join Date: May 2011
11-22-2012, 09:47 AM | #11 |
11-22-2012, 09:48 AM | #12 |
That's correct.
11-22-2012, 10:12 AM | #13 |
SIP
Thats right , I "shut it off" tuned it out with HPTuners when I installed the blower cam and changed out the lifters.
11-22-2012, 08:27 PM | #14 |
Thanks, guys. Yes, I did the AFM delete when I installed the turbos.
