12-17-2009, 07:15 AM | #1 |
Taking it 1 day at a time
Drives: 2010 Chevy Camaro 2SS/RS Auto Join Date: Apr 2009
Rut Roh... new error this morning....
Car started alarming with "Service Stabilitrack" this morning right before I parked the car.
/sigh
Order#: NJWGTF
1100, Preliminary order accepted 04/27/2009 6000, Delivered to the customer 07/23/2009 - 3 Months (worth the wait!!) |
12-17-2009, 08:48 AM | #2 |
Rumbly Bumble Bee
Drives: 2010 2SS Camaro Join Date: Aug 2009
Well...at least the paint is fixed!
2010 RALLY YELLOW 2SS 6M
-OBX Longtubes FTW! |
12-17-2009, 09:34 AM | #3 |
Drives: 2023 Black ZL1 Auto Join Date: Oct 2009
Hopefully the service department will treat you better and fix the problem the first time.
12-17-2009, 09:40 AM | #4 |
Well, went out to the car, and the Service Stabilitrack wasn't on. Suggestions? Is it worth taking back to the dealership for an issue that doesn't exist anymore?
Order#: NJWGTF
12-17-2009, 11:36 AM | #5 |
I doubt it, but you could call the service advisor and ask them to be sure before taking it in.
12-17-2009, 03:32 PM | #6 |
Drives: 1SSRS RY L99 Join Date: Aug 2009
These cars are highly computerized now and subject to same types of glitches as your home computer. There will be slight glitches here and there. There are many factors that affect wheel speed sensors, weather, temps, vibrations. If it only came on once, I would forget about it. The problem will be hard to find if it was only active once. Once the light goes out the system isn't detecting a fault. I wouldn't expect a tech to find a problem on a non-faulting system. It is always best to go to the dealer when the fault is active, or comes on all the time and they can reproduce it.
12-18-2009, 12:11 PM | #7 |
Drives: 2010 RJT 2SS/RS, 2001 Ford Focus Join Date: Jul 2007
There was a previous post about this. It stated that you may get this warning if you let go of the key before the engine completely starts. I get this if I just turn the ignition and let it go to start. It goes out within a sec.
12-19-2009, 11:03 AM | #8 |
Except I had been driving for over 30 minutes when it happened. I was driving through our parking lot and the alarm went off.
Order#: NJWGTF
12-21-2009, 12:52 PM | #9 |
'69 Owned Since '79
Drives: '69 Z/28 LeMans Blue w/White Join Date: Oct 2008
This happened to me once. I drove home from work and pulled into the garage as the warning came on. The next day all was fine. Never had any problems weeks after that so maybe this is no real biggie.
You can't fix anything that isn't broke. -Mark. |
12-21-2009, 01:32 PM | #10 |
The Mark of Excellence
Drives: 2010 ABM 1SS RS LS3 Join Date: Jan 2009
Were you out driving on the snowy/slushy streets before this happened?
BMR, CAI, DynoMax, Elite Eng., Hurst, Jannetty, Clear Image Headers & Hi Flow cats, Jet Hot, LSR, TSW, VMax, Vredestein |
12-21-2009, 01:34 PM | #11 |
Drives: 97 silverado Join Date: Aug 2008
i know it will throw that code if you dont plug the mass air meter back in.
i forgot to plug mine back in after i put on the intake and it turned off all traction control and told me to get stabilitrack serviced, plugged it back in and all is well. |
Similar Threads | ||||
#7157 Leaving holding yard this morning! | Rallyman6 | 5th Gen Camaro SS LS LT General Discussions | 7 | 06-11-2009 06:12 PM |
