02-01-2013, 05:25 PM | #1 |
[HOONIGAN]
Drives: 2012 ZL1 #1848[The HOONIGAN MOBILE] Join Date: Oct 2011
Oracle side markers
I recently received my oracle ghost side markers for my car the other day and so decided to install them today..however i ran into trouble when i couldn't reach my hand or see behind the small opening in the wheel well to remove the stock side markers. i looked up on youtube how to install them but all the videos only showed camaro models other than the ZL1. I thought the process would be the same regardless of model but im having trouble. anybody have any experience installing these? help?
2012 ZL1 BLack M6 ECF
02-01-2013, 05:27 PM | #2 |
Drives: '11 Camaro 2SS/RS LS3 Join Date: Jan 2012
You can jack the car up and remove the tires and liners to make it much easier.
02-01-2013, 05:30 PM | #3 |
[HOONIGAN]
yeah, i was just hoping to do it in my garage this weekend to get me excited for spring. But if cant figure it out ill just drop it off at the dealer and have them install it for me.
02-01-2013, 05:32 PM | #4 | |
02-01-2013, 06:20 PM | #5 |
Drives: Camaro ZL1 Join Date: Aug 2012
No way don't waste 200 bucks for them to install it, you can do it in 15 minutes!
-2013 Camaro ZL1-Black Stripe Package-Ambient Light Kit-Subwoofer Package-Sunroof-Suede Package-NAV MYLINK-MANUAL BABY-Dual Vented Fenders-Exposed Carbon Fiber Insert
-Black 10 Spoke Wheels 604 RWHP 602 LBS/TQ |
02-01-2013, 06:30 PM | #6 |
Drives: 2013 Black ZL1 Join Date: Dec 2009
I'm subscribed I also have Some oracle side markers to install
02-01-2013, 06:31 PM | #7 |
Drives: 2013 Ashen Gray M6 ZL1 Join Date: Sep 2012
I installed mine. Took about ten minutes for the first one then maybe five for the second one. Same amount of time for the back ones. There's a gap for the screw driver to slide into, at first I didn't push it in far enough, but then it just popped out. Really easy, no need to remove the tires or anything, not one screw, just follow the instructions. I watched a u tube video first then went out and gave it a try.
02-01-2013, 06:51 PM | #8 |
2018 Garnet Red ZL1 conve
Drives: 2013 & 2018 ZL1 vert Join Date: May 2009
AAC side markers
c4maroboy,
It's so easy, watch the DIY video again. It took me about ten minutes each side, use a really long skinny screw driver to push on the clip and they pop right out after you get the few screws and one 7mm bolt removed. You will really love them after there installed! I bought mine CRT ghosted from AAC and they look amazing!! (Light off/light on)
Build Thread: 2018 ZL1 Vert Purchased (Overpar73)
02-01-2013, 09:49 PM | #9 |
Only takes 5 min per marker light. Super easy. No need to lift, take tires off etc. in rear just pull back carpet side lining and youll have access
02-01-2013, 09:53 PM | #10 | |
Where am I?
Drives: Zoe the ZL1, 2012 Frontier Join Date: Apr 2011
FOR SALE: 2013 ZL1 Message me if interested |
02-02-2013, 06:36 AM | #11 | |
Here you go:
02-02-2013, 08:56 AM | #12 |
For the back two I jacked up the rear and went straight from underneath. Didnt have to remove any covers just did it blind by reaching up and feeling the clip and popping it out. Took less than 5 min a side. For the front the clips were giving me trouble so i removed the wheels and pulled the plastic back further
02-02-2013, 09:23 AM | #13 |
[COTW 5/12/14]
Drives: 2012 CRT NF Cammed 2SS/RS For Sale Join Date: Oct 2011
I know you may have wider tires than me, but just turn the wheel all the way in, take off one side of the wheel well and splash guards if applicable, and you can get in there. If its not coming then you are probably forgetting a screw. I think theres one holding the lens in place? And then theres one perpendicular to the light holding the fascia in place, and another from underneath. Just feel around and take out any screws until the fascia moves freely.
Might want to find the DIY heritage grille install video to show you where all the bolts are, since it involves removing the fascia entirely. EDIT I may be making too big of a deal about it, per the video above hahaha. Maybe there arent any screws holding it in. |
02-02-2013, 09:41 AM | #14 |
Sorry the video above was not for your ZL1, you only have to add the 7mm bolt going straight up really, really close to the fender lip in addition to the three screws. Good luck!
