Old 07-18-2020, 09:52 PM   #1
RKCamaro13
RKCamaro13's Avatar
Drives: 2011 Red 2SSRS A6
Opinions for Magnuson Setup
I know asking for opinions on a forum can sometimes be dangerous, but here it goes anyway.
I'm looking to add a Magnuson 2300 to my car pretty soon and wanted to get some input on the setup I was planning on.
I'm looking at the Magnuson blower with 1:1 cog setup. I'd also add a methanol kit just for safety and peace of mind, not looking to use to make a ton more power. Was thinking either Alky or Prometh with a trunk tank. Alky seems to be the most popular and proven, but Prometh seems to have a little better fit and finish in terms of fittings and is a little easier on the wallet (not trying to find the cheapest options, but not trying to break the bank either).
I know I'd have to upgrade the fuel system as well, but this is perhaps where I have the most questions. I was thinking of doing a ZL1 fuel pump with ADM FPCM, but I'm not sure if this is enough, don't really want to add a BAP. Looking to make somewhere around 600-625 RWHP. Also, would the injectors that come in the Magnuson kit be sufficient? I believe it comes with LS9 injectors which are 59 or 60 lbs I think. Or would I need to get a larger injector, 850s?
Any advice would be appreciated.
MPD1 Z Force hood, 1LE splitter, ZL1 rockers and diffuser, Heritage grille, Sparks Restorations emblems, Magnuson Supercharger, ID850 Injectors, Alky Methanol Kit, Livernois Fuel Pump Roto-Fab CAI, SW long tube headers, CNC ported throttle body, High flow cats, Lethal Racing Prowler Cam, LS3 conversion, Yank 3400 Stall, Corsa 3" cat back exhaust, RX Catch Can, BMR Suspension, BC Coilovers, Slotted and Cross-drilled rotors, Custom Interior.
RKCamaro13 is offline   Reply With Quote
Old 07-18-2020, 10:23 PM   #2
davidscamaro
davidscamaro's Avatar
Drives: 2010 SS/RS M6 BIG cam
Using meth will lower fuel demand, aside that the zl1 pump /mod fpcm can do 600whp-650whp with no bap if your tuner knows to for mod fpcm tune to zl1 tune on the adm fpcm
BIG cam ...... 305 45 18 Mickys ...... BMR suspensions
davidscamaro is offline   Reply With Quote
Old 07-18-2020, 10:31 PM   #3
Vegas Bound
Drives: 2013 Sparkly Red One
I made 659 whp with a LSA supercharger, ZL1 fuel pump and ADM FPCM and 65 lb injectors at 85% on 93 octane. No BAP necessary.
Forget the alky and go e85. Add an aux pump to the ZL1 pump and ADM FPCM and go to 1300 injectors.
Vegas Bound is offline   Reply With Quote
Old 07-19-2020, 07:48 AM   #4
RKCamaro13
RKCamaro13's Avatar
Don't really want to go e85, very few gas stations around me have it. I don't want to worry about finding an e8f pump when traveling either.
Old 07-19-2020, 09:14 AM   #5
Vegas Bound
Flex fuel.
Old 07-21-2020, 07:34 AM   #6
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
I don't think you need meth to be safe, IMO it makes things less safe as you take away fuel to run it, then if you have a failure you are lean, and boom. I tuned on 93, now I run 16oz of Klotz for safety. If you tune a car on 93, then just put meth injection on top of it you will actually reduce power. If going to 650whp I would probably add a BAP. I was at 600whp without it, 700whp now with the JMS and my fuel pressure is good. I have larger injectors than you are talking though. Might just get the bigger injectors if I were you.
Greenhornet2 is offline   Reply With Quote
Old 07-21-2020, 08:58 AM   #7
Yellow 1
Grumpy Grey-haired Guy
Yellow 1's Avatar
Drives: Camaro, Corvette & Merc C300(daily)
If you don't want to run meth, spend a fortune on a bespoke fuel delivery system and have the worry about high IAT's then I recommend you go Maggi Heartbeat 2.3L blower kit. Utilise a ZL1 fuelling system. Mine's making a solid 700hp with that kit, some long tubes, some decent heads and a factory cam. Drives like a *****cat til you get on it. Install looks like a factory fit, great well-engineered kit. Options with pulleys and ID1050 squirters to push it further if needed but for the street (here in Yewkay) 700 is enuff.
Yellow 1 is offline   Reply With Quote
Old 07-21-2020, 09:51 AM   #8
Vegas Bound
POMEs love this word bespoke.
Old 07-21-2020, 11:16 AM   #9
Yellow 1
Yellow 1's Avatar
Yeah - a bit ye Olde England - sorry!
Old 07-22-2020, 08:40 AM   #10
Juiced1
Drives: 2012 2SS CAMARO 45th
600rwhp is pretty easy to obtain with a supercharger. You can easily get there with out meth or E. My question is do you have specs on your cam? Is it a roots style blower? With a 3400rpm stall a roots blower might not be the best choice.
Juiced1 is offline   Reply With Quote
Old 07-22-2020, 12:40 PM   #11
Athletics101
Athletics101's Avatar
Drives: 5th Gen L99
Like Vegas said, do the flex fuel. It’s not even that much to throw into the cost of the kit, and will add a significant amount of power. You won’t have to worry about finding it since you can travel on 91/93. When your in the city tho, fill up on E. I have a vendor about an hour away I go pick up a 55 gal drum from. Since my car only need E 50ish to make the added power.
LSA conversion 2.5 upper 10% lower, L99 converted to LS3. TSP 229/244 cam, TSP LS3 ported and milled heads milled .015,Kooks LT’s no cats, Roto Fab, Borla arak cat back. 3200 stall,Forgestar F14 18’s and drag radials, pedders coil overs, BMR trailing arms & adjustable toe rods, mildly stripped Interior 685/613 on E 610/571 on 91
Athletics101 is offline   Reply With Quote
Old 09-29-2020, 08:10 AM   #12
abshire1006
abshire1006's Avatar
Drives: 2012 camaro ss
I’m running a Maggie 2300,3.4 pully night fury cam, zl1 fuel pump, 65 psi fast injectors, 93 pump gas making 619 jp and 590 tq, my car has 91600 miles on it, only issue I have had is clutch and axles, don’t need meth injection unless you plan on turning it up. I plan on doing meth soon, cuz like you e85 is hard to come by in louisiana, and I daily my camaro, it’s a fun little set up.
2012 SS, Magnuson supercharger, leathel racing night fury cam, ported throttle body, long tube headers,ACT twin disk clutch, BMR suspension, 620 RWHP 580 ftp 11.8 @121 1/4 mile time on 295/35/20 nitto nt555g2 tires
abshire1006 is offline   Reply With Quote
Old 09-29-2020, 12:13 PM   #13
eLeSthree
Drives: 2011 Camaro SS 6sp
I think the cog is over kill for 600. There was a guy who recently ran the heartbeat on a forged 376. Pretty sure he made 900ish with just the regular pulley type.
Wish he would have followed up on his thread. It was a very nice build.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT
1158whp 1017wtq.
2010 CTS-V A6 - "Stock" SOLD
630whp 658wtq
2024 F-150 RCSB 5.0 4x4
waiting for tunes...
eLeSthree is offline   Reply With Quote
