01-06-2015, 02:42 PM | #1 |
Drives: 2014 2SS 1LE AGM Join Date: May 2013
Dreaded month is finally here, what to do?
This is my first winter having the 1LE and this Thursday it's going to be 15 at night, thanks to the polar crap again. I knew it would be coming and it got here way faster than I hoped.
My question, I plan on storing my car in the garage from thur- till monday since that is when it will be back in the 40's again. It will be in the teens thur night and mid-upper 20's the rest of the nights. The garage is non-heated. Would it be ok to just put some blankets underneath the tires, so the tires are not on the cement floor? Thanks ! |
01-06-2015, 04:07 PM | #2 |
Drives: 2013 2SS/RS/1LE Join Date: Mar 2013
Read the Goodyear bulletin stickied in the tire thread at the top of this forum if you haven't already... the "If the tires have been subject to 20 deg F (-7 deg C) or less, let them warm up in a heated space to at least 40 deg F for 24 hours or more before installation or driving the vehicle" part in particular.
Mine is in storage all winter, I bought a sheet of 1" insulation foam from Home Depot, cut it into 4 pieces and park on that. My garage is also unheated but attached, temps near the car are usually 10 degrees above outside (I keep a thermometer next to the car, just 'cause I was paranoid about the tires cracking the 1st winter I stored it).
01-06-2015, 06:01 PM | #3 |
Drives: 2018 1SS 1LE Join Date: Dec 2012
I drove through 2 new york winters (sub 20degree weather) quite frequently and never had a problem with my goodyears. Just go easy.
01-07-2015, 11:01 AM | #4 |
Drives: 14 1LE Join Date: Mar 2013
They won't crack just sitting in the cold.
LMS Engineering
01-07-2015, 11:16 AM | #5 |
Drives: 2013 1SS 1LE Black - Std Exhaust Join Date: Mar 2013
01-07-2015, 11:39 AM | #6 |
36.58625, -121.7568
I'll be honest. my garage got down to 15 degrees last winter. I didn't move it one time when it was that cold. Usually I move it a few inches to appease my mind on flatspots, but when it was that cold I let it be. Never received any cracks. Now will the same thing happen this year when it does it again? Maybe, maybe not. It's a risk I take. My tires are nearly shot anyways. I read somewhere(don't remember where), to not touch them when it's below 20. So far, it has worked for me.
01-07-2015, 12:23 PM | #7 | |
first post is the bulletin: http://www.camaro5.com/forums/showthread.php?t=187045
LMS Engineering
01-07-2015, 12:32 PM | #8 | |
Drives: 2015 Camaro 1SS,6 Speed,NPP Exhaust Join Date: Dec 2012
And if your really worried get ya some tire warmers if your really considering putting blankets under your tires. |
01-07-2015, 12:36 PM | #9 |
B.O.D. 02/16/10
Drives: 2010 SGM Sp. Edition 2017 RS Conver Join Date: Jun 2010
Take them off and bring them inside.
01-07-2015, 12:57 PM | #10 |
Drives: E92 BMW M3 Join Date: Oct 2012
You should be just fine. Just make sure they are nicely warmed up to 40 ish as stated before you drive on them. To be honest, I drive mine if it is above or near freezing, the only time I park it is if it is in the 20's, and this is my second winter so far.
SOLD - 2013 1LE - Pat G Spec'd Cam, NPP with 1 7/8" Long Tube Headers with High Flow Cats, Intake w/scoop, Ported Throttle Body, and Apex 1.25" Lowering Springs.
J-Rod Built and Matt@FSP Tuned |
01-07-2015, 01:05 PM | #11 |
I do the same.
LMS Engineering
01-07-2015, 01:07 PM | #12 |
Drives: 2013 2SS/RS/1LE Join Date: Jun 2013
I've driven mine when it was 15*...a little slippery but manageable.
Pfadt LTs w/high flow cats and NPP. ADM CAI.
01-07-2015, 01:53 PM | #13 |
Thanks guys, I read the bulletin a few times throughout the year, however when it came time, I still wanted to ask.
I won't be driving again till next Tuesday more than likely, partly b/c I will be out of town. My tires have a few thousand miles left on them so I would like to keep these till the spring at least. I'll probably just put some thick carpet on the floor and park them over it. It's only suppose to be sub-20's tonight. After that it will warm up gradually. |
01-07-2015, 03:13 PM | #14 |
Drives: 2019 Chevy Equinox Premier AWD Join Date: Mar 2011
Shouldn't this be in the owner's manual somewhere??
2013 AGM 1SS/1LE, NPP, Camera
(1 of 43) |
