Old 12-12-2018, 11:42 AM   #1
Texas_craig
Drives: 2010 Camaro SS
2010 Camaro Drag Tires
looking at purchasing these tires for my camaro. 1. will they fit and
2. will i have any issues running them on the back and stock on front. here is the size
Slicks 26x11.5 17s 5x114.3 wheels are new and the tires just have few passes
Any advice is appreciated I am not a serious racer just playing around on a few weekends.
Texas_craig is offline   Reply With Quote
Old 12-12-2018, 11:46 AM   #2
Clarkstar
Clarkstar's Avatar
Drives: 2013 1SS 1LE
What's the offset???
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq.
Clarkstar is offline   Reply With Quote
Old 12-12-2018, 01:53 PM   #3
bayarea408
bayarea408's Avatar
Drives: T
26 inch tire is running small on a 5th gen. stock wheels are like 28.5. It may mess with your MPH calibration.
You running that small 26 in the back and a stock 28.5 in the front, be prepared for stabilitrack issues. You need to find a taller rear tire in 15/17/18 thats easy if you are down for a drag radial. MT, Nitto, M&H Racemaster etc...
we are also a 5x120... all that stuff about 5x114.3 fitting is true, but technically it isnt ideal. I personally would not do it, not drag racing...
bayarea408 is offline   Reply With Quote
Old 12-12-2018, 03:06 PM   #4
Texas_craig
I have an extra set of rims so I guess the best bet is to by NITTO 20
Old 12-14-2018, 02:10 PM   #5
bayarea408
bayarea408's Avatar
Drives: T
If you make FI power go for toyo R888 or the R compound in the 20". Im on Nt05R and its a joke anything below a 45, and mines an auto!!
Its really hit and miss for me with the NT05R sometimes she grabs most times it stutter steps and the back kicks out to the right HARD. then i have to pedal it
Old 12-15-2018, 03:27 PM   #6
10aSSee D
10aSSee D's Avatar
Drives: Silver 2010 SS Camaro
I’m having MT street SS drag radials mounted as I type this. Car is at home just brought the wheels to get tires mounted, when it stops raining I will see how they do and will let you know.
MODS:
Old 12-15-2018, 04:59 PM   #7
DSMer1
Drives: 14 and 15 SS's
Huh? 5x114.3 does not fit. I'm guessing you are think of the 5x120.65 (5x4.75)
OP, these are not going to work for you, keep looking.
Are you looking to drag race?
The R888 is not ideal for drag racing and would be the wrong choice.
Bolt-ons!
DSMer1 is offline   Reply With Quote
Old 12-19-2018, 06:59 PM   #8
bayarea408
bayarea408's Avatar
Drives: T
X2 my mistake meant what you said.
