03-10-2017, 04:46 AM | #1 |
Camaro #4
Drives: 2017-Hyper Blue Metallic-2LTmanual Join Date: Dec 2015
Silverstars, LEDs or HIDs
One of the guys at work is a part-time lighting installer at a local shop. I told him my stock headlights suck and he said he could get me into either LED headlights or HID headlights for under $100.
Which path should I take?
Don M
Supercharged LGX + 6 speed manual = FUN!! |
03-10-2017, 05:14 AM | #2 |
Drives: 2015 Camaro LFX A6 Join Date: Nov 2015
Interested in this as well. Have thought about swapping out my bulbs for silverstars... seems like the easiest, most cost effective thing to do. I think you can get a pair for about 50$
Definitely interested to hear other people's thoughts... HID's would definitely require more work and cost hundreds of dollars... Not sure about LED's ?
Cold Air Inductions CAI : Apex Air Scoop / WW Relocate Kit : JacFab Intake Manifold Spacer : Overkill 80mm Throttle Body : Overkill Tuned : MagnaFlow Cat-Back Exhaust : Elite Engineering Catch Can : ZL1 Strut Tower Brace : Custom Tunnel Brace : JPSS Caster Locks : JPSS 32mm Rear Sway Bar : JPSS Billet Radius Arm Bushings : Pegasus Solid Sub Frame Bushings : 1LE Brembo Conversion : B&M 70273 Trans Cooler
03-10-2017, 06:19 AM | #3 | |
Camaro #4
The kits he gets are also plug-n-play
Don M
03-10-2017, 07:24 AM | #4 |
Evil Genius of Chevrolet
Drives: 2017 Z06, 2019 XTS, 2013 SS Join Date: Feb 2017
Most hid are plug and play and only cost around $50. If you don't have an RS with projectors, go with hid not led. Led will only blind everyone coming at you. The hid made a big difference in mine but it wasn't enough so I changed to projectors, I can finally see.
03-10-2017, 08:00 AM | #5 |
What HID kit are you talking about for $50?
Cant be that great of quality for that number? Please share examples... Im interested in upgrading my lights...
03-10-2017, 11:07 AM | #6 |
I installed an opt7 hid kit. $54. It came with capacitors too. I expect to get at least a year out of it before I need bulb changes. I had the same brand on my Monte for years.
I really like their bullet hid kits because the ballast that's used. I bought it off Amazon. |
03-10-2017, 11:23 AM | #7 | |
Camaro #4
Don M
03-10-2017, 12:33 PM | #8 |
The leds will light up everything except the road. They are kind of like flood lights. Unless they are used in a projector headlight, it's actually worse, and dangerous for on coming drivers.
Leds are designed for projectors only. The hids will give a more focused beam because it's closer bulb type to a halogen. Therefore it uses your "headlight bucket" to its potential. A simple 35 or 55w hid kit will do the job. |
03-10-2017, 01:52 PM | #9 |
Drives: 2010 Camaro 2SS Join Date: Sep 2015
Yup got agree with that! LED's look really bright when you get out of the car and look at them but from the driver's seat you will notice the difference for sure. The light is not focused on the road in front of you. I'll also put my good word in for the OPT 7 kits, had 4 years of flawless lighting from my last set on my Monte and 3 in my Camaro.
03-10-2017, 04:49 PM | #10 | |
I have a feeling LEDs would work better in the non-HID lights. SilverStars are just Halogens like what I have now but brighter.
Mods, K&N CAI ,VTC , GM Perf Axleback Exhaust, Elite Eng CC and CSS, GM Strut Tower Brace,Carbon Fiber Anvil Spoiler,ASC T5 Splitter,Gen5diy Foglight kit.
03-10-2017, 05:26 PM | #11 |
Camaro #4
Now I'm getting confused ... is there a "Bob Is The Oil Guy" site for automotive lighting???? .... I know, I know ... GOOGLE IT
Don M
03-10-2017, 10:15 PM | #12 |
Led are for projector type headlights only, go ahead Google it....I'll wait.
Ino fact hid are only supposed to be for projectors too but they give a 360° light spread just like a halogen so they work in other types too. Led don't do that. |
03-11-2017, 04:06 AM | #13 | |
Camaro #4
Also, in my headlights, there is a 'cover' that the bulb 'hides' behind so there is no light coming directly from the bulb that actually shines outward, it's all reflected light from the sides of the bulbs. I will probably have to see both "in real life" at night to make a decision.
Don M
03-11-2017, 11:20 AM | #14 | |
