12-06-2013, 06:14 AM | #1 |
Drives: 2013 1LE Join Date: May 2013
Axle install ?
Is there any write up on on here for installing axles? Did a search and could not come up with much. Thanks for any info.
12-06-2013, 04:41 PM | #2 |
Drives: own more cars than i can list Join Date: Nov 2010
12-06-2013, 06:49 PM | #3 |
Thanks for the link.
12-07-2013, 08:37 AM | #4 |
Drives: 05 GTO Join Date: Jul 2009
Did you get them in Craig? It's not too bad of a job. The inner stubs should pop right out like I said on the phone. They can be a little stubborn sometimes but usually come right out.
I'll have to make a nice set of install instructions to include with them. Let us know how you like them once they are installed. Thanks Chris |
12-07-2013, 01:09 PM | #5 | |
12-16-2013, 07:35 PM | #6 |
12-16-2013, 08:04 PM | #7 |
12-16-2013, 08:23 PM | #8 | |
We won't be offering any gun drilled axles, gun drilling them makes them lighter but also weaker. |
12-16-2013, 09:47 PM | #9 |
10.11 @ 136.32
Drives: Black & Yellow 2SS/RS LPE LS7 427 Join Date: Mar 2010
Agreed that weight hurts but there is a lot of other places I'd look before worrying about extra weight that holding the wheels to the ground on launch.
Bryan
01-10-2014, 12:08 PM | #10 |
Eh, that'll happen
Drives: 2010 2SS Join Date: Apr 2012
Had a stock diff fully built up. Im installing GFORCE axles right now, but Im not sure if the axle is in all the way. It sound like it is bottoming out, but the clip doesnt seem to catching anything. I can easily pull the axle out. Ive given it a good push and it hasnt budged. What do you guys think?
2010 Camaro SS LS3 - No Modz
01-10-2014, 12:11 PM | #11 | |
01-10-2014, 12:13 PM | #12 |
Eh, that'll happen
Ok, will continue to work on it! Just didnt want to leave it like that. Thanks for the help!
01-10-2014, 12:42 PM | #13 |
Eh, that'll happen
Are they typically difficult to go in? I can get both sides in the same amount. I dont think it matters but I have a TruTrac in right now. Maybe the builder didnt line something up?
01-10-2014, 02:53 PM | #14 |
I remember when I was putting my stock axles back in, I had troubles like this. I lubed up the axle spline very generously, especially right around that ring. Before installing, try to center the ring in the axle groove evenly. I put the gap in the ring at the 6 o'clock position when pushing the axles in. And as a last ditch effort, I had a 4"x4" block of wood that held on the outboard edge of the axle and smacked it good with a 4 lb. dead blow hammer!!!! They certainly went in after that!!!! No....not a single-person job.
In comparison, I helped a buddy install a new rear end in his car a few months after mine, and I just had to wiggle the axle back-n-forth a little bit, give it a shove, and it popped right in!!!! Yeah, I was kinda pissed!!!! |
