12-26-2016, 11:47 PM | #1 |
Drives: 2015 Camaro 2SS 1LE Join Date: Feb 2015
AGP base kit dyno numbers
Well, dyno day was today....
830/783 @ 15.5 psi. 792 @ 13psi 683 @ 8.5psi AGP base kit 54/57 turbos AGP dual e85 430lph fuel pumps TSP stage 4 n/a cam Flex fuel FIC 1000 injectors Exhaust was wide open after mid pipes Can't be happier! The blood, sweat, and tears were definitely worth it.
AGP Twin turbo kit, base 54/57 Borg Warner turbos, TSP stage 4 N/A cam, AGP twin 430lph e85 pump fuel system w/ flex fuel sensor, 1000cc FIC injectors, Grimm speed manual boost controller. (830 rwhp 778 rwtq @ 15.5 psi)
12-27-2016, 07:32 AM | #2 |
Another well running solid build. That is a great combo. Turbos and fuel system, enjoy 800+rwhp. Could have done that with a stock cam too but PSI would have been 2-3psi higher because of the stock cam.
Great job.
Nick
Corvette Z06 -1200ish rwhp |
12-27-2016, 08:11 AM | #3 |
Drives: Black 2SS RS w/White Stripes Join Date: Mar 2011
Congrats! Welcome to the TT Club!
2010 2SS/RS "ChriSStine":
Pat G Custom Turbo CamMotion Camshaft | AGP TT BB Garrett 62/65's | AGP/Fore Triple Pumps | ID1700X Injectors | Alky Control Twin Nozzle Meth | Custom 3" Exhaust | 3.27 gear set w/ Tru Trac | McLeod Twin RXT | Barton Short Throw Shifter | 6th Gen ZL1 Wheels | BMR 1.4" drop springs | Pfadt rear trailing arms & tie rods | Installed by Me & Tuned by Pat G |
12-27-2016, 09:40 AM | #4 |
Drives: 2019 ZL1 1LE A10 Join Date: Jan 2015
Great setup man! The car is perfect.
Ryker #29
2019 ZL1 1LE A10 2015 Z/28 #809 |
12-27-2016, 10:15 AM | #5 | |
"Black Ace"
Drives: Supercharged 2010 SS, 2016 Golf R Join Date: Aug 2008
2010 2SS/RS M6 "Black Ace" - Delivered 6/4/2009
Mods: Forged 416 LS3, Maggie TVS 2300 SC (~11 psi), custom cam (232/247, .630/.630, 118 LSA), 90-lb. injectors, ZL1 fuel pump & ADM controller, Alky Control meth kit, Monster LT1-SC twin-disk clutch, ZL1 drivetrain conversion w/ DSS 1000-HP axles & 1-pc. driveshaft, CAI Inc. intake w/ ADM scoop, XS Power full exhaust (1 7/8" LT headers with 3" off-road pipes), VMAX CNC-ported TB, LSR adjustable sway bars, LPE rear end-links, BMR 1" drop, BMR polyurethane bushings; UMI trailing arms & toe rods. Built & tuned by Kraftworks. 755 rwhp/708 rwtq |
12-27-2016, 11:05 AM | #6 |
Served USN - Atomic Chimp
Drives: 13 Camaro LSX434 TT M6, 21 ZLE A10 Join Date: Jul 2012
Are you still on the stock pistons, rings (rotating assembly)?
In excess of 1,000WHP LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates |
12-27-2016, 11:07 AM | #7 |
Too much is never enough!
Welcome to the club!
12-27-2016, 11:30 AM | #8 |
Drives: 2013 Camaro SS Turbo Join Date: Apr 2014
Yes it's still stock motor
Nice numbers javi glad everything worked out!
12-27-2016, 11:57 AM | #9 |
Thanks brother. Couldn't of done it without your help!
12-27-2016, 02:23 PM | #10 |
2010 Camaro 2SS/RS LS3
1093/1066 416, AGP 6262, E85, Cam |
12-27-2016, 07:36 PM | #11 |
Drives: 2005 Corvette Join Date: Jan 2015
Good lawd
2005 Z51 Corvette, M6
ECS 1500 Supercharger Monster LT1-S Twin, AlkyControl Meth, ID1000's 220/240 118+3 Pat G Cam BTR Platinum Springs / Trunnion Upgrade, Z06 Manifolds/Exhaust Build Thread |
12-27-2016, 11:58 PM | #12 |
Drives: 2014 Camaro 2SS 1LE Join Date: Jul 2015
Nice numbers! Congrats!!
AGP TT 807whp 811wtq 13.46psi E85+methanol
12-28-2016, 11:41 AM | #13 |
"Black Ace"
Time to update that signature.
12-28-2016, 05:39 PM | #14 |
Drives: 2013 Camaro ZL1 Join Date: Nov 2012
Amazing! Congratulations!!!!
13 ZL1 A6
LSX 427 with AGP Twin Turbos, E85 and Flex Fuel. Built and tuned by ADM Performance 1000rwhp |
