08-09-2016, 07:47 PM | #1 |
Drives: 15' CRT Camaro 2SS/1LE/RS Join Date: Jan 2016
Front 1LE Splitter Removal
Has anybody here removed the front Splitter off the '14 /'15 1LE's? In addition to the plastic screw's are there metal rivets that I have to remove (drill through) to get the front splitter off?
Any help here would be great! Thanks guys. |
08-09-2016, 08:07 PM | #2 |
slower than you
Mine is riveted on. I'd assume that careful removal means the holes will be good for re-use
08-09-2016, 08:25 PM | #3 |
aerosportconcepts@gmail
Drives: '15 1SS-RS/1LE (RRM) Join Date: Dec 2011
Ya you need to drill out about a dozen rivets. Along the front edge and a couple at the back corners. Also it's a little tuff to get the hooked edges separated from the install bumper. Need to use a smooth trim removal tool to get those
Sent from my XT1585 using Tapatalk
08-09-2016, 11:09 PM | #4 |
Perfect - Thanks guys.
