05-11-2022, 07:37 PM | #1 |
Drives: 2013 zl1 vert Join Date: Dec 2018
og battery left me stranded.
It was only a matter of time, My og 2013 battery took a dive on me when i was at the softball park coaching my daughters 9-10 year old team. I new this time would come, good thing one of the parents had some jumpers.
What's a good battery to replace it with? No red tops they are junk, never had a good one. jt
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 1300/ dsx aux kit/ 103mm throttle body/ RPM 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ brick mod/BMR toe and trailing arms/ 751hp 757 tq SAE @17.3lb on a loaded dyno.
05-11-2022, 08:44 PM | #2 |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
whatever brand just make sure it is an AGM battery...
05-11-2022, 09:37 PM | #3 | |
Drives: ZL1, 2013, tri-coat-red, manual Join Date: Nov 2013
05-12-2022, 08:42 AM | #4 |
Drives: 2002 Camaro SS SOM; 2015 Malibu LTZ Join Date: Dec 2010
This happened to me, and my battery was fully charged (the car stays on a battery tender). Over time, the cells inside the battery wear out where it cannot hold starting power. Luckily a friend of mine had a portable battery jumper (It saved me a lot of grief and I learned a lesson). Now when I travel I make sure to have my portable jump starter handy.
'02 CAMARO SS SOM; 5.7L LS1/FLS6B
'08 TBSS AWD Black Granite Metallic '15 Malibu LTZ 2LZ Turbo '14 CAMARO ZL1 Blue Ray Metallic |
05-12-2022, 09:19 AM | #5 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
I had a fairly new battery that would land the car in limp mode on a hot start. It was a warranty replacement, so I did not take it back. I added three additional grounds and brushed the paint off where the main ground on the engine connects to the chassis as well as where the battery negative connects to the chassis. Same battery, problem solved. If I had bought a new battery it would have fixed the problem for a while again, but I am getting tired of buying $200 batteries and want to have more time between replacements.
2010 SS - On3 kit with downpipe cutout, CTR 78/80, CompCam 239/251 620/632 122+4, E85, Z28 suspension and ZL1 diff with Outlaw axles. Gen6 ZL1/1LE brakes.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
05-12-2022, 09:30 AM | #6 |
Drives: ZL1 Join Date: Dec 2016
The SEARS Platinum AGM sold at Advance Auto or the Odyssey AGM, both sold in Group H7/ Grp 94R
05-12-2022, 11:08 AM | #7 | |
05-12-2022, 11:19 AM | #8 | |
05-12-2022, 11:38 AM | #9 |
Just bought the Ac Delco from summit. Thanks fasnuf. $166 free shipping not bad.
05-12-2022, 02:25 PM | #10 |
Scott's45
Drives: 2012 2SS 45th Anniversary Join Date: Mar 2012
I bought a new battery a couple of weeks ago just for peace of mind. I was still on the original one since the car was new....so it's going on 11 years this November. It never gave me a problem, but I figured I'd change it due to it's age. I brought the original battery back to Advance Auto to get the core charge refund and asked them to test it just for the hell of it. They said it tested fine, still had 620 out of 750 cold cranking amps left! I'm amazed after over 10 years it was still good. Guess putting it on a battery tender every winter really helps.
2012 2SS 45th Anniversary, Hurst short throw shifter, Stainless Power LT headers, high flow cats, SW Retro Chambered 3" cat back, CAI, Heritage grill, tinted windows, red/silver hash stripes, AAC LED sidemarkers, blacked out turn signals/tail lights, splash guards. 402RWHP
05-12-2022, 02:28 PM | #11 | |
It don’t come easy.
05-12-2022, 08:13 PM | #12 |
