Old 12-04-2017, 04:28 PM   #1
joes2010SS
Drives: 2010 camaro SS
Thinking of going e85 and have fuel questions
Hi All, I purchased a 2010 camaro ss.
Reading around the forums and its been a great help but, I am thinking of switching to e85 or flex fuel.
Currently has the 85# fast injectors and zl1 pump and ADM FPCM. I am under standing that I need to most likely upgrade my injectors. I was thinking FIC 1000's. Would the zl1 pump be good enough if I get a Boost a Pump. I'm looking to reach over 700RWHP/750RWHP. Anything else I should purchase?
I have done some research but its pretty conflicting. I also don't have a local tuner to talk to yet. I do have somebody I'm going to be talking to in a month or two.
Stock bottom end LS3 376ci w/Manual 6 speed
Brian Tooley Racing PD Stage 3 Cam
Brian Tooley Racing .660 Springs
Brian Tooley Racing 7.400" 3/8" Pushrods
LSA Supercharger
2.50" Upper Pulley (10.5lbs of boost)
Straub Technologies Solid Trunion Kit
Melling High Pressure Oil Pump
85lb Fast Fuel Injectors
ZL1 Fuel Pump
ADM Fuel Pressure Control Module
ADM Cold Air Intake
Lingenfelter Dual Fan Heat Exchanger with thermostat
1 7/8'' Long Tube Headers w/Offroad Cats
160 Degree Thermostat
GM Factory Performance Axle Back Exhaust
McLeod twin disk RXT Clutch
Elite Engineering Catch Can
Coil Relocation Kit with MSD Plug Wires
Oracle Marker Lights
ZL1 Replica Wheels
Inferno Orange Interior
Running on 93 Octane
Dyno tuned by ADM Performance (Andy Mages) in Lewisville, Texas
joes2010SS is offline   Reply With Quote
Old 12-04-2017, 06:33 PM   #2
hammdo
'It's an experiment'
hammdo's Avatar
BAP is not enough for E85.
DSX has an e85/aux pump kit and he’ll reprogram your FPCM for free. That is what I’m running..
Injectors will be needed as you noted, I have the ID1050x... making 747 RWHP, 794 RWTQ...
-Don
747 RWHP 794 RWTQ
Old 12-04-2017, 07:27 PM   #3
PerryIomSS
Drives: 2013 Iom SS/1LE
Hammdo with the DSX kit did you have to run a bigger fuel line. Also you a running a ZL1 pump correct. I am getting everything to put a procharger on my 1le and have read a lot of your stuff.
PerryIomSS is offline   Reply With Quote
Old 12-04-2017, 07:35 PM   #4
hammdo
hammdo's Avatar
It comes with everything. I did have to tap into the fuel tank and I do have a zl1 fuel pump.
This may give you some help:
http://www.camaro5.com/forums/showth...385577&page=92
-Don
747 RWHP 794 RWTQ
Old 12-04-2017, 08:07 PM   #5
fif_gen_powa
fif_gen_powa's Avatar
Drives: 2013 Camaro SS Turbo
Sell all the ZL1 stuff and just do a real twin pump setup with flex fuel, AGP has the best priced setup, squash and fore have complete kits as well
388ci 91/104 Turbo TH400
8.3@164
https://instagram.com/turbo_ls3/
fif_gen_powa is offline   Reply With Quote
Old 12-04-2017, 08:12 PM   #6
gsxrturbo
Drives: 2010 ss
I AGREE,get yourself a twin pump and be done.Its a lot of money but well worth it.
gsxrturbo is offline   Reply With Quote
Old 12-04-2017, 08:57 PM   #7
Unavowed
Unavowed's Avatar
Drives: Twin turbo G8 GXP
Not necessarily. I have a V pump, Vaporworx controller, JMS booster and ID850'S, plus meth and on E50 make enough power to trap 143-145.
Unavowed is offline   Reply With Quote
Old 12-04-2017, 10:17 PM   #8
joes2010SS
I really appreciate the input!
Old 12-05-2017, 02:08 AM   #9
Slickcas
Drives: 12' 2SS/RS LS3 IBM
Been looking myself also. The DSX kit looks very nice and will get you to 1000+RWHP. It keeps the factory FPCM with ZL1 pump. So it will keep the PSI perfect with out running balls out all the time. So you have factory reliability and quiet with a booster pump kicks on at a preset psi like 8 or 10 of boost. If you like to drive a lot this kit seems the best.
They are right AGP has what seems the best twin/ triple pump setup for the price. The twin with E85 setup is $1800. It’s a really nice setup.
I am leaning towards the DSX kit. But never know with me lol.
Slickcas is offline   Reply With Quote
Old 12-05-2017, 09:13 AM   #10
BiggFoot
BiggFoot's Avatar
Drives: 2010 Camaro (M6) 1000+ HP SBE
OP looks like you already received some good advice, more pump and injectors will be needed.
How do you like the McLeod RXT Twin? I am getting one installed next week.
F-1X, Cog Drive, ATI Super Pulley/Sprag ~ 19 psi
Blower Cam
Brodix BP BR 3 Heads
Kooks LT Headers and full 3" exhaust
Fore Triple Pump Fuel System with ID 1700X Injectors - E85 conversion
DSS 9” Conversion (1400 hp axles, driveshaft, pumpkin) & Strange 3.70 gears
McLeod RXT Twin HD Clutch & Upgraded Slave
RPM Level VII
TR6060
BMR Drag Suspension Package w/Strange shocks
Carlyle 15" and M/T ET Street R radials
10.1 @ 143 mph 1/4 mile
BiggFoot is offline   Reply With Quote
Old 12-05-2017, 10:23 AM   #11
Unavowed
Unavowed's Avatar
I just can't get past drilling a hole in my gas tank and mounting an external pump. Seems like for not much more money you can get a viable in-tank solution. Either AGP or ACE performance. I'm contemplating this now too.
https://www.aceperformance.biz/produ...in-walbro-450/
Old 12-05-2017, 11:06 AM   #12
scv_guy
scv_guy's Avatar
Drives: 2010 Camaro SS
I'm currently running that setup and it works great!
Made 750rwhp with tons of room to go...
scv_guy is offline   Reply With Quote
Old 12-06-2017, 03:28 AM   #13
Slickcas
Never seen that ACE set up. Like to see some more information on it. Like better pictures. Be good for the OP and every one else also.
Old 12-06-2017, 04:34 PM   #14
mrimpala02
Drives: Black 2SS RS w/White Stripes
Does the ACE setup retain the bucket so you don't have to always worry about fuel at 1/4 of a tank?
2010 2SS/RS "ChriSStine":
Pat G Custom Turbo CamMotion Camshaft | AGP TT BB Garrett 62/65's | AGP/Fore Triple Pumps | ID1700X Injectors | Alky Control Twin Nozzle Meth | Custom 3" Exhaust | 3.27 gear set w/ Tru Trac | McLeod Twin RXT | Barton Short Throw Shifter | 6th Gen ZL1 Wheels | BMR 1.4" drop springs | Pfadt rear trailing arms & tie rods |
Installed by Me & Tuned by Pat G
mrimpala02 is offline   Reply With Quote
