03-10-2015, 04:15 PM | #1 |
Drives: 2011 2ss/rs Join Date: Nov 2011
SS Diff, 3.91, jannetty posi mod. $?
I have an ss diff, oem 3.91, jannetty posi mod, and bmw bushings. Whole diff has 20,000kms. 3.91s posi mod have 10000kms. Had a new pinion bearing and new side bearings, when gears where put in. Nothing broke or blew just replaced when had the gear set put in. What should I get for it if I were to sell it?
03-10-2015, 05:44 PM | #2 |
Sorry I can't answer your question but what exactly do you benefit from the posi mod?
2010 Camaro 2SS/RS | 416 LS3 | FED stage 2 heads
03-10-2015, 06:38 PM | #3 |
Drives: 2017 Camaro SS1LE 2000 Trans Am WS6 Join Date: Jul 2008
I'd say around $1000.
2017 Krypton Green SS 1LE
Magnacharged 2000 Trans Am WS6 manual trans 2002 Trans Am 2015 Ram Crew Cab Cummins |
03-10-2015, 07:19 PM | #4 |
Drives: 2010 SS L99 IOM Join Date: Aug 2012
I say I'll come and pick it up off your hands for free- it's just a burden to try and sell it
...if you were to sell it $900-$1200 maybe
369rwhp/392rwtq
"Spending money I don't have, to buy parts I don't need, to impress people I don't know!" -Jenkins |
03-10-2015, 07:33 PM | #5 | |
More clutch packs and a tight preload spring for the limited slip. Makes it alot harder for one wheel to lose traction. So for if you were to launch at the track you may get one tire spinning a lot and the other just hanging out. This helps keep both wheels doing the same thing. When you see a car doing a burnout and only one wheel is doing anything. This prevent that. |
03-10-2015, 08:30 PM | #6 |
I've seen another one without the posi and only 7k miles on it for like 850 on here.
Another member has a 1Le diff with the axles for like 1250 shipped. A lot of them are currently in the "classifieds" section. Check out what they are going for and factor in your mileage and posi mod..
03-10-2015, 08:32 PM | #7 | |
03-10-2015, 08:40 PM | #8 |
Maybe not truly necessary, but it just aids in traction. More traction is always a good thing
03-11-2015, 07:47 AM | #9 |
I have a JRE 4.11 diff with 3500 miles on it with the billet caps, posi mod, BMR bushings that I am selling...trying to move it locally first
2010 Camaro SS Whipple SC, CAI Inc Intake, TSP 1 7/8" LT headers no cats, 3" magnaflow exhaust, HPT, RX Catch Can, LSR Toe Rods, LSR Trailing Arms, ALKY Control Meth, McLeod RXT Twin Disc, ZL1 fuel pump, 3.73 ZL1 Differential Kit, BTR PDS Stage 2 Cam, Tuned by SLOWHAWK Performance Bridgewater MA
03-11-2015, 10:17 PM | #10 |
How much does a stock ss diff weigh?
03-12-2015, 05:09 AM | #11 |
A little over 90 pound range without fluid
