05-29-2009, 08:53 PM | #1 |
Drives: 2011 2SS/RS A6, IOM Join Date: May 2009
Slotted or cross drilled rotors
Why am I convinced that the SS/RS package had slotted or cross drilled rotors but all the pictures I see show regular rotors?
05-29-2009, 09:00 PM | #2 |
they dont come with them. I can tell you the slotted ones are not cheap to replace.
2010 1SS/RS Black, CGM stripes, polished Rims, Tinted windows, Hurst shifter
05-29-2009, 09:02 PM | #3 |
I was wrong
Went to the Camaro build your own site and it shows regular rotors. OK folks, first mod I'd do is to get some crossed drilled rotors. This car screams for that, even it is "just cosmetic" which it isn't if you drive hard..
05-29-2009, 09:05 PM | #4 |
Nards, you're right
But I have gotten good mileage on Brembo cross drilled. Pirelli P Zeros arn't cheap either. It's the price you pay for vanity and performance.
05-29-2009, 09:08 PM | #5 |
"That Guy"
Drives: Camaro SS...........what else? Join Date: Apr 2009
Location: OOOOOOOklahoma where the wind comes sweepin' down the plains.
well then you might as well go with cross drilled carbon ceramic rotors....lmao.
way too much!
05-29-2009, 09:08 PM | #6 |
why not research first then ask.get your car first.
05-29-2009, 09:50 PM | #7 |
Drives: 1999 30th Anniversary Trans Am Join Date: Oct 2008
slotted and cross drilled rotors are of no benefit and nothing but a gimmic. Well unless you are running abspestos pads
05-29-2009, 09:55 PM | #8 |
Ancalagon The Black
Drives: 2013 Silverado 4X4, 2010 RJT 1SS Join Date: Nov 2008
I saw pictures of an SS with cross drilled rotors several months ago but I am sure it was a prototype.
06-01-2009, 09:20 PM | #9 |
Drives: . Join Date: Mar 2009
WRONG. Cross drilled/slotted rotors do have a purpose. After replacing brake pads and especially during their brake in period, when they heat up so do their binding agents, causing them to release gasses. These gasses can cause the brake pads to lose contact with the rotor. The drilled holes/slots help to release these gasses as well as add some heat dissipation. Now like most aftermarket items these too are derived from race cars, but never the less do have a purpose or you would not see them on just about every type of race car/motorcycle.
06-01-2009, 09:36 PM | #10 |
Outlaw
Drives: 2010SS Join Date: Jan 2009
+ They're lighter and unsprung
06-01-2009, 10:00 PM | #11 | |
Drives: 2SS/RS Join Date: Sep 2008
Today the only benefits that cross drilled/slotted rotors have over solid rotors is lightening your wallet with the premature cracking which leads to early replacement and using up your pads quicker so you have to replace them more often. But hey they do look good. |
06-02-2009, 01:15 PM | #12 | |
Cutting thin slots across the face of the rotor can actually help to clean the face of the brake pads over time, helping to reduce the glazing often found during high-speed use which can lower the coefficient of friction. While there may still be a small concern over creating stress risers in the face of the rotor, if the slots are shallow and cut properly, the trade-off appears to be worth the risk. (Have you looked at a NASCAR rotor lately?) Since I have seen glazed brakes on passenger cars, it seems that there really is a use for these cool looking rotors.
06-02-2009, 07:29 PM | #13 | |
Waiting For My 1SS/RS SIM
Drives: Sold My Lancer, now carless :/ Join Date: Apr 2009
I have no idea who is right, but if you would read his post he is saying the difference between Nascar and a Passenger car is that the vehicle doesn't break at high enough speeds to produce the gasses so having them on a passenger car is pointless. So, the entire rebuttal you just typed is not even countering his argument which clearly was your intention here, you may of even back peddled. Just saying... |
06-02-2009, 09:33 PM | #14 |
Drives: Trans Am Join Date: Apr 2009
GM didn't put cross drilled rotors on the Z06 and ZR1 as a gimmick. They serve their purpose in a racing environment. On the street, however, you will probably not realize the benefits of them unless you run your car like you're at a road course. Which some folks do.
Similar Threads | ||||
Front Ground Effects Lip Problem | Lucky SOB | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 130 | 03-08-2010 03:53 PM |
Brake upgrade | 96CAMaro | Wheels and Tires Talk Sponsored by The Tire Rack | 28 | 06-03-2009 01:44 PM |
ZR1 brakes? | UsedTaHaveA68 | Wheels and Tires Talk Sponsored by The Tire Rack | 33 | 03-15-2009 07:34 PM |
Are the SS Brakes Drilled? | Scott@Bjorn3D | Wheels and Tires Talk Sponsored by The Tire Rack | 19 | 11-16-2008 04:47 PM |
