Old 08-22-2012, 12:49 PM   #1
V6owner
Cedar Creek Woodshop
V6owner's Avatar
Drives: One Badass 1LE
Track strategies
Just thought I would make a thread in this section for us track guys. If you have any special techniques you wanna share on launching or burnouts or anything just post them up here
What rpm do you guys launch at? I usually launch about 1800-2000 rpms
How long of a burn out? I usually spin my tires in the water a second so when I get out of the water pit both wheels will spin and not just one since I don't have a LSD Posi rear end yet. An then smoke the tires pretty good and slowly roll out of it
How many of y'all are using line lock on automatics? Manuals?
I hope to break 12's this Friday might if I can make it out to the track!
Alex
2014 Black 2SS/RS 1LE
V6owner is offline   Reply With Quote
Old 08-22-2012, 01:23 PM   #2
Can't_C_Me
Don't Sleep on My V6
Can't_C_Me's Avatar
Drives: 2016 C7 1LT
When I launch I usually launch with the TC on the when out of 1st I turn it off. Great torque management technique.
Sent from my iPhone 4s using Tapatalk
Can't_C_Me is offline   Reply With Quote
Old 08-22-2012, 02:02 PM   #3
BaylorCamaro
Track > 1/4 Mile
BaylorCamaro's Avatar
Drives: 2016 C7 Z51
Launch at around 1800 but I may start trying to launch harder. I've always kept TC on but now that I have a LSD and nitto DR's I may try launching with it off and seeing how that goes. I basically do the same for my burn out.
I've thought about getting line locks. I'm debating if it's worth it, if I'll go to the track enough. I usually only go twice a year.
BaylorCamaro is offline   Reply With Quote
Old 08-22-2012, 02:05 PM   #4
V6owner
V6owner's Avatar
I turn my TC and stabilitrack all off the whole time
Old 08-22-2012, 02:32 PM   #5
Yellow_Glide
Yellow_Glide's Avatar
Drives: 2011 1LT "Chakita". 04 Yota
Strategy #1: quick out of the hole and drive fast...
Hi, my name is Chakita. I have cams!!!!
Build thread: http://www.camaro5.com/forums/showthread.php?p=3847083
Yellow_Glide is offline   Reply With Quote
Old 08-22-2012, 02:37 PM   #6
BaylorCamaro
Track > 1/4 Mile
Drives: 2016 C7 Z51
Really? How hard do you launch it, floor it o ease into it?
Old 08-22-2012, 02:56 PM   #7
V6owner
V6owner's Avatar
Pedal to the metal!
Old 08-22-2012, 02:57 PM   #8
BaylorCamaro
Track > 1/4 Mile
Drives: 2016 C7 Z51
Pedal to the metal!
Interesting, and not much wheel spin? Even with the new rear end and TC on I still get some wheel spin. Well I did with the OD pulley, not sure now.
Old 08-22-2012, 03:03 PM   #9
smoke1lt
smoke1lt's Avatar
Drives: 2011 1lt/rs/sim
I turn everything off ,rev the hell out of it,floor it and dump the clutch at the same time
RX-SUPERCHARGED/RX SUPER CHILLER/RX TB/RX PORTED IM/BLACK ICE-OLATER/BBK LT HEADERS/HFC/ARK-DTS CATBACK/EIBACH SPRINGS AND SWAYBARS/ORION SUBS AND AMPS...next mods RX od pulley ,3.91 gears
smoke1lt is offline   Reply With Quote
Old 08-22-2012, 03:04 PM   #10
V6owner
V6owner's Avatar
3 of the 4 runs last track visit I spun a little but last one I hooked good
Old 08-22-2012, 03:04 PM   #11
GretchenGotGrowl
GretchenGotGrowl's Avatar
Drives: 11 F150 EB/13 Sonic RS/15 Z06
Warm those DRs up and launch with TC with your new differential. I would then just launch at lower RPM if track prep isn't very good. The SS differental makes a world of difference when launching.
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread
GretchenGotGrowl is offline   Reply With Quote
Old 08-22-2012, 03:10 PM   #12
BaylorCamaro
Track > 1/4 Mile
Drives: 2016 C7 Z51
Yeah but the thing is Houston Raceway Park (now Royal Purple Raceway) is known for having one of the better NHRA track preps in the US. Maybe I'm not heating them up enough
Old 08-22-2012, 03:21 PM   #13
GretchenGotGrowl
That would be my guess. Really let them have it. Remember to roll into the gas, don't just stab it when you release the break.
Old 08-22-2012, 07:52 PM   #14
scrming
Red Brick of Vengeance!
scrming's Avatar
Drives: 12 Second Brick
Alex
DO NOT SPIN YOUR TIRES IN THE WATER! Surprised they haven't yelled at you... you need to pull out of the water before you start your burn out... other wise you'll end up spraying water up in your wheel wheels... and then it will drip down when you really don't want it to!
scrming is offline   Reply With Quote
