09-05-2012, 09:16 AM | #1 |
Cedar Creek Woodshop
Skinnies
What are y'all using for skinnies in the front?
I heard you can use GTO spares but I heard you can't also Also heard you can use CTS-V spares Anyone else have a fairly cheap option to use? Thanks Alex
2014 Black 2SS/RS 1LE
09-05-2012, 09:40 AM | #2 | |
Drives: 11 F150 EB/13 Sonic RS/15 Z06 Join Date: Sep 2010
There really isn't a cheap way to go. If you want to keep your V6 front brakes then I think you can find some wheels and tires that will fit at a place like JEGs or Summit Racing. If you get 18' wheels then it is a real pain finding skinny tires that will fit.
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread |
09-05-2012, 09:41 AM | #3 |
Red Brick of Vengeance!
Drives: 12 Second Brick Join Date: Jun 2009
Well, people were using spares..... however a number of tracks seem to be cracking down and not letting people run spare tires, since most of them have like a 55 MPH rating... Personally I would avoid using a spare..
09-05-2012, 09:51 AM | #4 |
Well damn!
How much are a decent light weight pair of skinnies?
09-05-2012, 10:12 AM | #5 |
Tires won't be cheap if you are trying to stay around the stock diameter. I found some on JEGs that are for 17 inch wheels and are 28" tall (close to stock). I think they were about $250 each. Of course they will last a long time, but I would have to be racing every weekend to justify $700+ for wheels and tires up front. For now I'll just keep using my road tires and worry about it once the car is lined out and can consistently make it all the way down the track.
09-05-2012, 10:18 AM | #6 |
Drives: 2010 Camaro 2SS/RS 6MT Join Date: Apr 2010
Do you have a stock spare? I'll sell you mine if you want. Pop those two on there and you're good to go. Most spares are rated up to 55 MPH, but those ratings are for speed over time. 30 seconds or less at high speeds and you will be fine as long as you let them cool down, which means you should be fine.
09-05-2012, 10:20 AM | #7 |
Drives: 2010 Camaro Join Date: Feb 2010
You don't want to go the "cheap" route when working on the most critical part of your car. That's just plan not bright. I'll never understand why 90% of this site spends tons of money modding their car and then doesn't want to spend a little more to do it right.
09-05-2012, 10:25 AM | #8 | |
09-05-2012, 11:05 AM | #9 | |
It's really none of my business but more often than not this is where you find people trying to cut corners. |
09-05-2012, 11:19 AM | #10 |
Drives: 2012 Camaro RS, RX supercharged Join Date: Dec 2009
Supercharged SS is correct. We have the ricers come with super fast rotaries locally and have the 55 mph temp spares on the front. They get mad when kicked out but it is not if they want to die or wreck their car...it is the guy in the other lane and the spectators that are at risk.
Dont cheap out on drag tires/wheels. |
09-05-2012, 11:33 AM | #11 |
Banned
Drives: Camro Join Date: Aug 2012
09-05-2012, 11:36 AM | #12 |
09-05-2012, 11:37 AM | #13 |
Thanks guys I never looked at it in that aspect
What's an average price for a decent set of skinnies?
09-05-2012, 11:41 AM | #14 |
All I can comment on are the Bogarts. They run about $625-$650 each plus caps and lugs. The tires are on the M and H site. I'm not sure about the price. Expensive yes, but if you really need them it means you have a hella fast car and want to be safe.
