Old 09-09-2013, 09:59 AM   #1
blkngldbabe
Barossa's handler
blkngldbabe's Avatar
Drives: 2LT/RS RJT
3.73 or 3.91 gears
Hey all. I've been seriously considering the change up in gears. More giddyup off the line and a fairly inexpensive zip provider since I can't afford FI currently. My concern is the tune. Is it necessary and how hard is it to deal with since we have that lovely programming nightmare in our beasts? I drive Barossa year round so I'm not sure which gear I should go with. I'm not concerned about top end loss as I'll never hit it TBH. Gas mileage is a bit of a concern but really, I'm not that bothered since I get pretty good mileage currently IMHO. Any thoughts on this? ANyone have either set ups?
SLP's GTA Master Specialty Vehicle and Master Parts Dealer
blkngldbabe is offline   Reply With Quote
Old 09-09-2013, 10:32 AM   #2
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
Are you an auto or manual?
Old 09-09-2013, 11:05 AM   #3
IneedAZ
IneedAZ's Avatar
Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr
Before last week if u were to ask me i would say go 3.73, but i just swapped my 3.73 for 3.91 and i like it. Car feels better, stays closer to the power band. I am at 2000rpm at 65 and 2500 at 80.
Sold 2012 2LT RS 12.3@112 old setup
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS.
2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17
2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47**
Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver
Daily Driver 2021 BMW M340i Xdrive
IneedAZ is offline   Reply With Quote
Old 09-09-2013, 11:34 AM   #4
blkngldbabe
Barossa's handler
Drives: 2LT/RS RJT
I'm a manual. Did you need a tune to deal with the speedo?
Old 09-09-2013, 11:41 AM   #5
RubyCamaro
Jan
RubyCamaro's Avatar
Old 09-09-2013, 12:10 PM   #6
IneedAZ
IneedAZ's Avatar
Yes, without the tune u will be 10-15mph off depending how fast u are going. Matt at FSP did a good job getting me within 1mph at all speeds yesterday.
Also, you are lucky u dont have the big expensive of a complete rear swap.
Old 09-09-2013, 12:11 PM   #7
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
You will need tuning. Swapping to 3.73 will result was an equivalent torque gain of approximately 15% or 41 lb.-ft. of torque and will raise 70 MPH cruising RPM from right at 2000 to just under 2300. Going to 3.91 will get you in the neighborhood of a 20% torque gain and put you over 2400 RPM at 70 MPH.
Old 09-09-2013, 12:20 PM   #8
blkngldbabe
Barossa's handler
Drives: 2LT/RS RJT
Thanks for all the info. I'm afraid I may have issues getting the tune up here in Canada though.
Old 09-09-2013, 12:24 PM   #9
lscamaro
lscamaro's Avatar
Yes, you'll need a tune to adjust the speedo.
If you're going to do it, I'd do the 3.91. They're gm products and I believe less expensive too. The only problem is that you'd need a tune. I don't know if ipf adjusts for gears and I just wouldn't do a trifecta tune
Old 09-09-2013, 12:44 PM   #10
blkngldbabe
Barossa's handler
Drives: 2LT/RS RJT
I'm definitely favoring the 3.91's due to the sweet pricing but since I drive in the snow, will the extra torque be a severe issue? I usually start off in 2nd gear when it's slippery anyways and have only been stuck once (2 foot dump of snow and the road hadn't been cleared at all yet) in three years. I also need a tune for it and don't know if I can get IPF to hook me up, up here. Anyone have any thoughts?
Old 09-09-2013, 12:58 PM   #11
RS111341
RS111341's Avatar
Drives: 2011 SS IOM auto
Hypertech has a speedo calibrator that'll fix your speedometer and Autoanything sells them pretty cheap
RS111341 is offline   Reply With Quote
Old 09-09-2013, 01:07 PM   #12
right to travel
Drives: 2013 Camaro 1SS 1LE SW
3.91 wont void warranty with tune and install from gm dealer
right to travel is offline   Reply With Quote
Old 09-09-2013, 01:20 PM   #13
blkngldbabe
Barossa's handler
Drives: 2LT/RS RJT
IS there a GM tune to work with it since it's a factory gear? That would rock
Old 09-09-2013, 01:22 PM   #14
right to travel
yes. see your dealer if they are not tards. if they are find another one. the gm performance mag for the month just dropped and lists a bunch of stuff to add on that wont void ur warranty if done at the dealer.
