Old 05-09-2010, 02:16 PM   #1
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
Wheel Sensor Stem hits Brake Line... what to do???
Put my new wheels on and didn't get 2 blocks before I started hearing tic tic tic tic...
The rubber valve stems on the rear wheel sensors are hitting the emergecy brake line. I took the wheels off and tried to adjust push the line in a bit, but there is not much you can move.
Does someone know of a good fix for this?
Thanks in advance...
Old 05-09-2010, 02:30 PM   #2
killinemsoftly
killinemsoftly's Avatar
Drives: Summit White L99 2SS Forgiato 22"
I took my caps off the stems and they don't hit anymore
White 2SS H&R Springs, Blacked out emblems and lights , black roof, Forgiato Martellato Custom Painted 22's
killinemsoftly is offline   Reply With Quote
Old 05-09-2010, 03:00 PM   #3
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
Tried it... even if that did work aren't you concerned it's still too close?
Old 05-09-2010, 03:07 PM   #4
4SD FED
4SD FED's Avatar
Drives: 2010 rs/ss camaro
Zip ties
4SD FED is offline   Reply With Quote
Old 05-09-2010, 03:09 PM   #5
killinemsoftly
Yea but I'm gonna have em zip tied
Old 05-09-2010, 03:17 PM   #6
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
Originally Posted by 4SD FED View Post
Zip ties
I only saw one place to zip tie them too and it's the ABS line... not real good.
I even pushed the line in through the gromet where it's attached to the frame and put a zip tie on one end in an attempt to keep it from sliding back toward the wheel. No help.
Old 05-09-2010, 04:41 PM   #7
Gotthat02fire
Gotthat02fire's Avatar
Drives: 2010 Camaro 1ss IOM
Someone makes aftermarket tpms sensors I don't know how short the stems are though ask nineball!!!!!!!
Gotthat02fire is offline   Reply With Quote
Old 05-09-2010, 04:55 PM   #8
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
That would work... hate to buy new sensors but might be my only option. I will be checking w/ Tony since I got the wheels from him anyway.
Old 05-09-2010, 05:07 PM   #9
Gotthat02fire
Hope it works out let me see if I can find that link!!
http://www.tpmswholesalers.com/?gcli...FciA5Qodbj_m_g
These look pretty short hope that helps! I would still wait for Tony either way!!!
Old 05-09-2010, 06:36 PM   #10
jrpxxii
jrpxxii's Avatar
I have a set of aqdapters that I will sell you for $50 as this is the best option for using the tpms. These are specific for tpms in these isssues. They normally cost $75 but I am not using tpms and will try to help you save some money.
Old 05-09-2010, 06:49 PM   #11
killinemsoftly
I had Discount Tire order my Forgiato's and they put in new sensors and I didn't even reset the car automatically sensed them.
Old 05-09-2010, 06:57 PM   #12
Darth_Emma
Psssssssssshhhhhhhhhhhhh!
Darth_Emma's Avatar
Drives: under contruction
I ordered my wheels and TPMS from nineball. I was also concerned about the rear wheels rubbing the brake lines. I'm putting 315s on the back. PQ did as well. He said if you zip tie that brake line it prevents the rubbing. Nineball (Tony) said it would be a non issue. You might want to contact him to see if the TPMS he sells will help you out.
Old 05-10-2010, 02:49 AM   #13
urr2slo
urr2slo's Avatar
Drives: 2010 2ss ss/rs abm, 2016 2ss/rs hbm
you can firmly push the park brake cable through the holder and then use a small hose clamp around it to keep it from sliding back through the holder, you only need to push it back an inch to inch and a half, problem solved.
URR2SLO - If you're not going fast enough, get out the way......
urr2slo is offline   Reply With Quote
Old 05-10-2010, 06:42 AM   #14
Supercop29
Old Cop!
Supercop29's Avatar
Drives: 2SS/RS
Zip hand cuffs... work great on mine !
Supercop29 is offline   Reply With Quote
Stainless Steel Brake Lines on Sale MTI Racing Kevin Suspension / Chassis / Brakes 17 12-02-2010 12:05 PM
2SS Silver Ice Metallic at ATL Car SHow Cmurf_SS Camaro Photos | Spyshots | Video | Media Gallery 40 11-09-2009 09:38 PM
Minimum size wheel on SS Brembo Brake JEFF2010SSMANUAL Wheels and Tires Talk Sponsored by The Tire Rack 57 10-21-2009 01:04 PM
Wheel weights on Brake Calipers. chef5330 Wheels and Tires Talk Sponsored by The Tire Rack 1 07-31-2009 04:40 PM
Brake upgrade 96CAMaro Wheels and Tires Talk Sponsored by The Tire Rack 28 06-03-2009 01:44 PM
