08-16-2015, 03:44 PM | #1 |
Ride On!!!!
FOR SALE: SJM/Night Owl Door/Dash/Cup Holder Kit
These are 3 kits from SJM using NightOwl Controllers.
I decided not to install them as I may be selling soon. Door Kit: Lower Pipes (I already had stock ABL), 4 RGB LEDS, each able to be controlled individually by NightOwl LP Module. If you don't want to install lower pipes, you can use the 2 extra LEDs for door pull and door handle illumination. Dash Kit: 2 Pipes for the dash, 3 RGB LEDS, also each able to be controlled individually by NightOwl LP Module. Cup Holder: Gloss Black cup holder cover with 4 RGB LEDS, all controlled individually by NightOwl LP Module. Wiring Harness: makes this all plug and play. harness taps into existing power and you can piggy back the dash kit and the Cup holder. Door Kit plugs into existing wiring. Looking for around 500$. If kits purchased separately, they are close to 650$.
08-16-2015, 05:00 PM | #2 |
HTCC Membership Director
Drives: 2013 RS Camaro Join Date: Jan 2014
If you decide to seperate, I would be interested in the cup holder cover.
08-16-2015, 06:12 PM | #3 |
Ride On!!!!
Will definitely keep you in mind. Would you want the harness as well?
08-17-2015, 02:48 PM | #4 |
I have the harness as I already installed the dash lighting and used the PnP harness for that.
08-23-2015, 12:46 PM | #5 |
Ride On!!!!
any interest anyone?
08-23-2015, 09:20 PM | #6 |
2010 transformer
Drives: 2010 ss camaro Join Date: Nov 2014
What colors
2010 transformer, vertical doors, 315nt05 rears, pedders supercar coilovers, hotchkis sway bars, links, adjustable, toe bars, bmr poly cradle bushings, 1le control arms, bmr tunnel brace, bmr subframe connectors. Cam 227/239-623-620@114 Mast medium bore heads, sw 1 7/8 headers, cat delete, x pipe, 3" dynomax true duals, fuel rails, fast 102 intake and NW 102 throttle body, catch can, rotofab cai, shifter, raptor custom shift light. Dss drive shaft, 3.91 gears. 492 rwhp
08-25-2015, 04:38 AM | #7 |
Ride On!!!!
These are all RGB. All come with NightOwl LP modules.
08-25-2015, 07:51 PM | #8 |
Pm me price for the dash kit and the door ones
09-03-2015, 06:37 PM | #9 |
Ride On!!!!
Still looking for reasonable offers
